Author Topic: Completed: Vickers F.B.5 Gunbus, Bluemax 1/48  (Read 22387 times)
Re: Vickers F.B.5 Gunbus, Bluemax 1/48
« Reply #60 on: June 01, 2022, 11:25:27 AM »
And I agree with them: your photos betray nothing of the trials you went through. Beautiful!
Offline Naimbs
« Reply #61 on: June 17, 2023, 04:47:33 PM »
Hi there,
A few months ago, I made the brackets from brass scrap, cut with chisels, and drilled to be inserted at the end of each of the masts (0.5mm). Holes of 0.3mm are also drilled to accommodate the struts when the time comes.
It should make my work easier for the struts, and it's a big plus in my opinion.
And today I started installing them:
In detail:
All that remains is to do the same for the lower wing.
See you soon!
Arnaud
« Reply #62 on: June 17, 2023, 05:28:00 PM »
Arnaud,
You are Totally Insane...In a that is crazy Great  work Insane  8)
« Reply #63 on: June 17, 2023, 09:06:56 PM »
Outstanding work on the brackets Arnaud!
Offline PJ Fisher
    • Aero Rarities
« Reply #64 on: June 17, 2023, 09:53:12 PM »
This is over the top!  Truly inspiring.
« Reply #65 on: June 17, 2023, 11:35:36 PM »
Very inspirational effort Arnaud. Lovely work on the fabric looks and the metal work is fantastic!
Eagerly awaiting your next post.
Tim
« Reply #66 on: June 18, 2023, 12:38:58 AM »
Wonderful work, those brass fittings are beautiful.
Offline Naimbs
« Reply #67 on: June 18, 2023, 05:07:21 PM »
Thank you very much!
Normally, everything's in place to start installation of the upper wing.
It's not too bad.
The cabin struts aren't glued on the photo, but they're exactly on the right axis and perpendicular.
I gave it a try, and the top wing sits nicely on these 4 struts. The anguish for me will be the installation of the 8 interplane struts  ....
I've never built a model with so many struts.
And then.... Pray for me  ;D .... You can't go wrong
Arnaud
« Reply #68 on: June 18, 2023, 09:53:38 PM »
You don't need our prayers, you're work is incredible. This is a really beautiful Gunbus!
« Reply #69 on: June 18, 2023, 11:58:34 PM »
Spectacular work. Lovely colours and delicate shading. It will be a masterpiece.
« Reply #70 on: June 19, 2023, 01:04:28 AM »
I can't say it any Better! Beautiful!!
Offline Naimbs
« Reply #71 on: June 19, 2023, 09:06:57 AM »
Hi there!
You're all too kind, and it's far from finished!  :)
I'll be satisfied when it's finished! For now, there's still a long way to go!  :-X
Well, after several hours of fumbling, grumbling, breaking, unsticking, redoing etc, I think this should do it.
It's almost too rigid. I don't know how else to explain it. I'm hoping that the interplane rigging will prevent some of the struts from detaching under tension.
The two posterior cabane masts were a hair too long, and impossible to get them off the fuselage. I had to cut half a millimeter off their wing tips with pliers, without being able to attach them before the other struts. In short, I had a hard time...
I'll be able to move on to the rigging soon! This is an important stage in the assembly. The one that had me shaking in anticipation with this old Bluemax kit. Probably my most difficult assembly to date.
See you soon!
Arnaud
« Reply #72 on: June 19, 2023, 11:13:31 AM »
In spite of the difficulty you have done a magnificent job. Keep the Faith, you will conquer the rigging.
« Reply #73 on: June 19, 2023, 03:34:43 PM »
Fantastic work! I really like you making your own brackets, and the result as well! Would you mind detailing the manufacturing of those a little bit more?
« Reply #74 on: June 21, 2023, 08:11:48 AM »
I had missed these new posts: incredible work with the brackets - my hat off to you. Having some experience with Gunbuses in different scales I can only congratulate you on getting the struts to line up so well - that is no mean achievement. Brilliant modelling.
