Author Topic: Roden 1/32nd Scale SSW DIII: Udet Jasta 4  (Read 45083 times)
Re: Roden 1/32nd Scale SSW DIII: Udet Jasta 4
« Reply #105 on: May 28, 2021, 03:09:03 AM »
Definitely a good step forward with the lozenge and Lo markings. It was interesting to learn that the Lo was only on one side of the fuselage when publicity photos were taken.
« Reply #106 on: May 28, 2021, 03:20:40 AM »
There are No Known photos that show the Lo emblem applied to the left fuselage. IIRC, Udet was wounded the following day flying his DVII. He later returned to the Jasta but too late to do any more combat flying. It is therefore doubtful that the LO! was ever added to the left....But who knows for sure  ???
« Reply #107 on: May 28, 2021, 06:11:04 AM »
Awesome!
Great progress now in this project.
Do you plan to add rib tapes? Ok ok, this may slow down your progress ....
« Reply #108 on: May 28, 2021, 06:35:17 AM »
Very nice looking, Rick.
« Reply #109 on: May 28, 2021, 10:03:57 PM »
Awesome!
Yes, the rib tapes will take a while Frank  :D
Thanks Ken!
« Reply #110 on: May 29, 2021, 01:32:14 AM »
Great progress here, Rick -
A model always seems to come more to life once you start to get the decals on.
« Reply #111 on: May 29, 2021, 03:30:01 AM »
Looking good so far Rick:
Just to be different I would put the "LO" on both sides, but that's me.  It probably wore them at one time.  Looking forward to the final "Reveal".
« Reply #112 on: May 29, 2021, 03:39:08 AM »
I agree completely. They do make things look much better!
The "Funny" thing is that by Not Putting on the LO on both sides I am going against the Norm. Most Modelers apply it to both sides in spite of the photographic evidence  8)
« Reply #113 on: May 29, 2021, 05:51:44 AM »
Before I progress further I have two questions:
1. I see some builds that used edging on the leading and trailing edge, and others that have not. Is there a consensus?
2. The upper wing fit to the struts: I have seen Various differing solutions from No mods to shortening the rear of the interplane strut, thru Shortening the rear cabane strut. Again, any consensus?
Thanks for all advice,
« Reply #114 on: May 29, 2021, 11:09:51 AM »
Hi Rick ,
I didn't add taping the edges of the main wings . After studying photo's it is really hard to tell , but I can't see that join not being protected . Whether they should be coloured is another question as well . Some folks have used blue tapes or a linen tape for this and I don't think that is over accurate . Lozenge tapes make more sense to me and is likely what they used . In the end Rick no one really knows for as we know a lot of info was lost of the years man has been at war and lost to time . Also taken into account that this is a late model D.III , early version could have had coloured tapes .
The cab struts are the right length , inter struts need to be trimmed . The front strut needs more shortening then it's rear counterpart . Can't recall , but trim to fit works  ;)
Offline Fvdm
« Reply #115 on: May 29, 2021, 03:22:13 PM »
The lozenge looks real good. Applying the ribtapes isn't an easy job but you already know that I presume.  Take your time.
« Reply #116 on: May 30, 2021, 11:18:54 PM »
Hi Rick ,
Thanks Alexis. I will continue to study the other build logs before I attempt to attach the wing.
Thanks. I am halfway through the upper wing as of this morning.
« Reply #117 on: June 01, 2021, 11:09:06 PM »
How are your taping adventures coming along ? ....no pressure  ::) :o ;)
« Reply #118 on: June 02, 2021, 04:56:43 AM »
Putting rib tapes on is a task that would drive me utterly crazy. You must have the patience of a saint Rick!!
« Reply #119 on: June 02, 2021, 11:56:18 PM »
It has been slow and at times frustrating  :( More on the Frustrating Part later.
There are a lot of them to deal with on this aircraft. Hopefully all done and touched up by tomorrow  ::)
