Author Topic: 1/72 MAC Distribution Phonix DIIa K.U.K Kriegsmarine  (Read 13667 times)
« on: April 18, 2021, 07:31:19 PM »
Dear all
Decided to take the plunge on doing a group build.   I normally worry when I do these in case I make a foul up and also this will really only be an OOB build.
So, without further ado I present this kit that I will soon start:
So please wish me luck!
More will follow in due course
Re: 1/72 MAC Distribution Phonix DIIa K.U.K Kriegsmarine
« Reply #1 on: April 18, 2021, 08:56:03 PM »
Dave, of course: Good luck!
Hmm, I'm not sure about the colors on your box.
Some time ago I have done a Phönix D.I in 1/48:
https://forum.ww1aircraftmodels.com/index.php?topic=8558
If I'm not wrong there are some pages about the Kriegsmarine in the Windsock Datafile 31 "Phönix D.I-II".
« Reply #2 on: April 18, 2021, 10:53:57 PM »
Looking forward to your build Dave  :)
« Reply #3 on: April 19, 2021, 12:29:10 AM »
Likewise!
« Reply #4 on: April 19, 2021, 01:27:48 AM »
Looking forward to seeing this come together, not an aircraft I am at all familiar with.
« Reply #5 on: April 19, 2021, 02:43:24 AM »
Ah, this a nice one Dave!
« Reply #6 on: April 19, 2021, 03:03:29 AM »
Thank you all, kindly folks!
Frank - thank you for lovely build of this aircraft.  Not sure about the colours myself but the instructions state these ones had a green mottle applied.
I'll have a think on it and consider this once I finally get that stage.
In the meantime, I have washed and dried the kit so will most likely start this in the next couple of days.   Here is a shot of the sprues and what is included in the box.
« Reply #7 on: April 19, 2021, 04:30:03 AM »
This one will be interesting Dave. A-H aircraft generally seem to be under-represented on modelling sites so it will be good to see another being built. OOB or modified I know from past experience that this will be another gem to add to your collection.
« Reply #8 on: April 19, 2021, 07:26:26 AM »
It's definitely a start.
Offline Fvdm
« Reply #9 on: April 20, 2021, 05:14:29 AM »
Good luck Dave.
Offline Stuart Malone
« Reply #10 on: April 21, 2021, 02:44:53 AM »
Best of luck Dave!  I have a bunch of MAC kits in my stash but haven't built one yet.  I'll be looking forward to your opinion of the kit.
Stuart
« Reply #11 on: April 21, 2021, 03:48:01 AM »
Thanks, folks!
This MAC kit is a first for me also, Stuart - I will soon be making a proper start on this one so should have initial work to share soon.
« Reply #12 on: April 21, 2021, 05:16:08 PM »
This looks interesting. I have developed a soft spot for A-H aircraft for some reason, especially KuK Kriegsmarine.
 I built the MAC Fokker D.VII a few years back and it went together fairly well. I replaced the engine with a spare Roden one and made new struts but otherwise I don't recall any problems with it.
« Reply #13 on: April 22, 2021, 05:37:14 AM »
Thanks, Ian!
Right, I've actually made a (very) small start on this one today.
The cockpit (as all the kit) is pretty basic (and some part detail is a bit on the crude side) meaning there are minimal parts supplied and seem simplified.   That said, dry fitting the fuselage halves shows that the cockpit opening is such that not much will be seen anyway.
Both the engine and seat attach to the one floor.   Engine is made of several parts and the crackcase and cylinders are two piece affair that will need a bit of clean up and maybe some filler once glue has fully dried.   Here is the part in question:
I'll attach the rest of the engine components once I finish cleaning up this part.  Stick and rudder are supplied as very fine PE (urgh! - I hate working with PE parts) parts so will attach them once the rest is built and painted.  Instructions give no guide as to what colours should be what within the interior.   I will therefore go with wood for cockpit floor, inside of fuselage and instrument (also PE part) panel.  Not too sure about the seat - probably wood?  PE fret also provides tiny four point harness that will require some careful fitting.
One half of the fuselage has the annoying raised pin marks that will interfere with the engine fit if not removed as seen (apologies for poor quality photo) here:
I cut this away with rounded model knife blade:
Looking as the exhaust part shows some flash and seams to remove prior to fitting.  I intend to drill out the exhaust openings once I get this.
More progress to follow in due course.
« Reply #14 on: April 22, 2021, 07:26:39 AM »
Good start Dave. The parts do look pretty basic as you write, but as little will be seen that will not matter too much.
I hope that the injury on your finger was not inflicted in the course of this build.
