Author Topic: WingnutWings FE2b - another problem  (Read 3490 times)
Offline 6992
« on: February 20, 2021, 05:17:39 AM »
Construction of the WingnutWings FE2b continues - rather slowly due to arthritic fingers (and it not being the simplest of things to deal with !).
The WnW instruction booklet continues to occasionally irritate due to lack of clarity / failure to name components / "pretty" but misleading 3D drawings. This one has really got me scratching my head >
Page 16, wing rigging guide. The upper wing has an aileron control cable pully near to each wing end - BUT what happens to the cable above the wing between those two pulleys. The illustration shows the cable following the wing angle down to the centre section (which makes sense) - but what holds the cable down to follow that route rather than a straight line between the two pulleys ?
Also, I still haven't found a scaled drawing for the FE2B with "V" undercarriage. (The WnW instructions would have benefited from some good two-dimensional drawings).
6992
Offline hrcoleman66
Re: WingnutWings FE2b - another problem
« Reply #1 on: February 20, 2021, 09:56:34 PM »
There are guide loops at either the straps that secure the outer wing panels to the centre section.
Hugh
« Last Edit: February 20, 2021, 10:09:13 PM by hrcoleman66 »
Offline 6992
« Reply #2 on: February 21, 2021, 07:40:24 AM »
Thanks for the reply; - yes those are the two areas which I'm looking at, but I cannot see any part numbers for anything which could be described as "guide loops at either the straps". I suppose I should just make something up !
6992
Offline hrcoleman66
« Reply #3 on: February 21, 2021, 02:41:48 PM »
I looked through the images of the WNW website of the kit parts and I couldn't see anything either.
Making a couple (four) of copper wire loops should be fairly straight forward.
Hugh
Offline 6992
« Reply #4 on: February 25, 2021, 07:05:03 AM »
... Making a couple (four) of copper wire loops should be fairly straight forward.
I've made four very small diameter loops out of thin brass wire and glued them into drilled holes almost flush with the top of the upper wing. The installed aileron control wire "looks right" in terms of its positioning above the wing, but I suspect that WnW possibly intended you to just glue the rigging to the bracketing mouldings on top of the wing  ??? I'll get there in the end  :)
6992
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #5 on: February 25, 2021, 06:10:45 PM »
There are seven small tubes attached to the top wing which the aileron control wire passes through. Here is a rather poor photo, I'll try to find a better one
Happy Modelling
James Fahey
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #6 on: February 25, 2021, 06:32:37 PM »
Slightly better closer in photo of one of the seven tubes (on the left side)
Happy Modelling
James Fahey
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #7 on: February 25, 2021, 06:58:47 PM »
I think this may be the best I can do for you, it's a small detail from a much larger photo
Happy Modelling
James Fahey
Offline Dave J
« Reply #8 on: March 02, 2021, 10:30:40 AM »
These aren't supplied in the kit. I just had a look on the WNW website at my two builds to remind me what I did and I didn't do anything. Just ran the wire across the points.
Dave Johnson
Wellington, New Zealand
Former Wingnut Wings Dungeon Master, Sales & Logistics Manager
Offline Europapete
« Reply #9 on: March 04, 2021, 12:26:12 PM »
Awesome photo's, thank you James. Regards, Pete in RI
Offline Jamo
  • Wellington, NZ
    • My Smugmug album
« Reply #10 on: March 05, 2021, 08:16:01 PM »
I was back at the TVAL hangar last weekend and the Fee was parked close to a balcony where I could see over the top wing. Unfortunately the lighting was very dim, but these shots show the aileron control cable thingees more clearly
James
Happy Modelling
James Fahey
Offline Petie2nd
« Reply #11 on: March 06, 2021, 12:06:10 PM »
Thanks James. Is "thingees" one of those highly-technical aeronautical terms?  ;)
Pete
Offline Dave Brewer
« Reply #12 on: March 06, 2021, 01:46:43 PM »
Thanks for these photos James, filed for use on my build; these provide the sort of clarity that seems to be needed on most WNW builds at some point, as good as the instructions generally are.
Dave.
Offline Europapete
« Reply #13 on: March 06, 2021, 10:37:21 PM »
Dang! I like your camera! These pics are going straight into my FE2 box. So......is there any chance the Tval crew can bring you every plane they have while you are up in that balcony??? hmmm???  Regards, Pete in RI
