Author Topic: Halberstadt CL.II, Mirage 1/48; 20.3.2021 Parabellum - THE END  (Read 65502 times)
Halberstadt Cl.II, Mirage 1/48; 18.3.2021 Question for picture
« Reply #195 on: March 20, 2021, 07:28:55 AM »
Towards the end I start thinking about the next one and lose focus!
Guy, that is the reason, why I wrote I should concentrate on this one ???
Don’t loose focus on the last 100m !
I'm still running this 100m sprint ... not yet finished.
You do not have to bother because your models are just sooooo good.
Thank you Stephen for your continued support!
And now a question:
on the profile of this bird in the manual is a very small picture on this aircraft in crashed state, see left:
Sorce: http://modelnewsinfo.de
Edit: if the picture do not load (since this is no https) here is the direct link:
http://modelnewsinfo.de/wp-content/uploads/2016/11/MIR481306_HalberstadtCLII_camo1.jpg
Below the picture is the text:
Halberstadt Cl.II 14277/17 '3' Schlachtstaffel 26b, spring 18, Bissighem airfield
crashed during take off, pilot Paul Schwarze (heavily injured), gunner Franz Schumm (killed)
Does anyone know this picture in better quality and can tell me, if there is a AirSpeed Indicator on the left strut?
It is may be visible, but the print quality of this small picture is not good enough.
The colored profile shows one, but the big profile in the Windsock Datafile there is none.
I could mount the Gaspatch one.
« Last Edit: March 20, 2021, 07:48:15 PM by Bughunter »
« Reply #196 on: March 21, 2021, 07:49:37 AM »
Parabellum
In a last sprint I added again a lot of details.
At first some engine tuning for the Mercedes D.IIIa. I turned a sprue and added stretched sprue.
Together with a turned brass part it completes the front of the engine.
The weapon for the gunner is needed too. Here I don't used the kit part but a Eduard Brassin with resin and PE from my stash.
But for the barrel and jacket I used a Master set, which don't need to be rolled. Already chemical blacked here. Until now I have used only Spandau MGs from Master, because this is my first German two seater.
The Parabellum is complete, here on the Eduard manual drawing.
I tried to mount it, but run into trouble. It doesn't look nice - the mount is the reason!
There is no kit PE, so I had to create my own mount. The first one made from a brass rod brakes so here is the result of the second try - used 0.3mm brass. Left the original one. I found also some wing nuts on an old Eduard PE!
The new one in comparison to the plastic block. I waited with removal until the new one is finish, just in case ...
Removed with accident and the new one mounted.
Now also the Parabellum fits.
May be you remember my wooden spool with aerial wire? This needs an outlet. I replaced the kit plastic by metal pipes.
After some paint I added the same wire as on the spool with a drop of solder as weight. Nice detail ;)
And I decided finally to add a airspeed indicator (made by Gaspatch Models). The were grey green or black. I used black to have a little contrast to the grey green strut. My first mount was more filigree, but the this brass brakes, so I used a PE stripe.
And in final position:
All the prepared parts are now mounted, for example the air screw, but I don't have more pictures.
The Halberstadt CL.II is finished now, so again a project come to the end.
Thanks for watching and commenting! This was a great fun to build this nice aircraft and I hope you had some fun too.
Re: Halberstadt CL.II, Mirage 1/48; 20.3.2021 Parabellum - THE END
« Reply #197 on: March 21, 2021, 08:01:13 AM »
Really Outstanding Build in all Aspects Frank! I did get joy out of watching!
« Reply #198 on: March 21, 2021, 04:32:22 PM »
Great work Frank! Really fun to follow and both your photos and text really help showing the different steps. Even if most of what you do is pure magic! 😃
« Reply #199 on: March 21, 2021, 08:24:45 PM »
Cl. IV next?
« Reply #200 on: March 22, 2021, 04:43:24 AM »
Another master class in modelling completed Frank. Those extra details mark out one of your models from those which the rest of us make!
« Reply #201 on: March 22, 2021, 05:29:31 AM »
That was a stunning and amazing build Frank! There were so many useful details and amazing techniques! Regards, Marc.
Offline hrcoleman66
« Reply #202 on: March 22, 2021, 06:50:27 AM »
I keep forgetting this is 1/48 :o
Amazing details!
Hugh
« Reply #203 on: March 23, 2021, 06:19:43 AM »
Thank you Rick, Fredrik, Andreas, Stephen, Marc and Hugh!
Cl. IV next?
Negative, Ghostrider!
The Cl.IV moved magically very deep into the stash. My kit allows 3 markings, I do not like the "gas mask" face, another red flames nose (not, that is already in the cabinet) and a boring normal one. Let's see ...
No, I have so many interesting kits to build, let's see. And some shelf queens
If one is useful for you, then it was worth the effort!
Offline Fvdm
« Reply #204 on: March 26, 2021, 05:08:27 PM »
Terrific build. I learned a lot from this.  Thanks for sharing with us.
