Author Topic: WnW Hannover Cl.II finished (with a footnote)  (Read 35753 times)
Re: WnW Hannover Cl.II
« Reply #150 on: May 06, 2021, 02:43:02 AM »
I have to thank everyone who have taken the time to comment on this build - it's very much appreciated, and I'm on the homeward stretch!
A couple of photos to add - somewhat stepping back on the build a bit. Options of what to rig these 1/32 models with is something I have mixed opinions on. But at least the stretchy EZ-Line thread will allow some movement of the flying surfaces without showing a sag, and for me that's helpful.
It was not until I'd completed construction and rigged the tail section that I added the wings to this model. Then I saw that the tail was tilted off to the left - the solid joint of the horizontal stabilizer on the fuselage was somehow "out". So I had to remove the small struts in the tail, and manually "bend" the stabilizer (and the upper tailplane) to line up parallel with the wings. Then I replaced the struts and touched up the paintwork. Very scary job, but at least it looks straight now, and the rigging behaved nicely without having to remove/replace it.
Also - I've got into the habit of dipping my glazing in a diluted X-19 Tamiya Smoke mixture. This gives a "scale" effect to the windscreen once it's dried off.
The tail section before I had to manually twist it into alignment with the wings.
The windscreen after a dip into diluted X-19 Smoke for scale effect.
« Reply #151 on: May 06, 2021, 05:42:23 AM »
You are certainly knocking this kit out in good time.  As mentioned, the paint work is outstanding.  Nice and clean and smooth.  The decals on the fuselage give it a nice touch and breaks up the lozenge nicely.  Nice too to see it up on the undercarriage.  Those pesky tail surfaces can be a real pain at times, but you overcame that without a mishap, always a good thing.
« Reply #152 on: May 06, 2021, 08:45:40 AM »
Excellent progress and quite simply Beautiful work!
« Reply #153 on: May 06, 2021, 08:50:10 AM »
Spectacular, all around and in details. I especially like that touch on the windscreen.
« Reply #154 on: May 06, 2021, 10:20:19 AM »
Mark, Rick, and Prze - so glad you guys like it. I'm currently trying to put some finishing touches on the figures. It's hard to believe the detail on these Model Cellar miniatures. Painted all with Vallejo acrylics.
The mechanic
The pilot (still need to glaze the goggles)
« Reply #155 on: May 06, 2021, 10:40:59 AM »
Allows admire your painting on those little people , and I will have to remember the smoke on the wind screen that really adds to it !
« Reply #156 on: May 06, 2021, 01:12:00 PM »
Thanks for that Alexis - I think painting miniatures is probably my favourite part of the hobby.
« Reply #157 on: May 06, 2021, 02:57:21 PM »
They look fantastic Gary!
And I think the colours and the weathering are spot on!
You must have steady hands!
« Reply #158 on: May 06, 2021, 03:29:50 PM »
Breathtaking progress on fuselage and figures, Gary.
« Reply #159 on: May 06, 2021, 06:51:01 PM »
Great work, Gary. It is like in a candyshop, I don't know what attracts me more, the perfect painted plane or the perfect painted figures.
Bye,
« Reply #160 on: May 07, 2021, 02:58:28 AM »
Well you do a good job of painting them.   The pilot figure strongly rsembles Herman Goering.  Again, outstanding work Gary.
« Reply #161 on: May 07, 2021, 05:46:04 AM »
As always your figures are superbly painted! Gorgeous work!
« Reply #162 on: May 08, 2021, 05:48:41 AM »
Willem, Andreas, Manni, Mark and Rick thanks! Such nice comments  8)
Well, I finished the model and have taken a few pictures for the "Completed Models" section which I hope to post soon. Thanks to all for taking a look and following my build, and for the help I got along the way. Kensar - thanks again for that book, it was an immense help!
Offline Fvdm
« Reply #163 on: May 08, 2021, 06:07:20 AM »
Awesome! What a beautiful plane. You can be proud of yourself.
« Reply #164 on: May 08, 2021, 08:12:26 AM »
Turned out pretty durned snazzy Gary.  I'd give a hearty Marine OUTSTANDING.  The figures and the mounting set it off nicely.  You did an outstanding job on the Lozenge fuselage, smooth, clean, Outstanding.  This should Garner some Gold at Nanton this year if they have it.
