Author Topic: WnW Hannover Cl.II finished (with a footnote)  (Read 35513 times)
Re: WnW Hannover Cl.II
« Reply #135 on: April 29, 2021, 11:37:31 PM »
Thanks to all for the comments and work continues on the model.
Yes, Martin - I think oil paints are a good idea and always incorporate them in some form to enhance detail and dirty things up a bit. Also, light coats of Tamiya X-19 smoke seem to tone things down nicely. The effect is subtle, and one can go too far without knowing...so I've learned to do a little bit and come back later to add more if necessary.
To add some interest to the eventual display of the model, I decided to paint these two fellows up. They are from Model Cellar. I'll add the heads after the bodies get painted separately.
Offline Fvdm
« Reply #136 on: April 30, 2021, 02:26:42 AM »
Hmm, this pose, so close together? Is he proposing? ;D
« Reply #137 on: April 30, 2021, 09:41:20 PM »
Possibly, but only while he adjusts straps. ::)
« Reply #138 on: May 01, 2021, 02:09:38 AM »
The figures look terrific and of course will be even better once you do your Magic with the painting!
« Reply #139 on: May 03, 2021, 11:20:55 PM »
For rigging this model, I've used a combination of copper wire loops, EZ-Line elastic thread, and RB Productions etched metal turnbuckles. Luckily there isn't a ton of lines to add, but there are those tricky rods to place between the wings - and I used 0.5mm pencil graphite for that. After they're painted up, the turnbuckles will be a bit less noticeable.
« Reply #140 on: May 03, 2021, 11:49:33 PM »
Gary, you are producing something very special here, any modeller would be proud of this. It really is looking fantastic.
« Reply #141 on: May 04, 2021, 12:03:41 AM »
The rigging looks excellent as does the rest! Pencil graphite, something that Never would have crossed My mind but it is effective!
« Reply #142 on: May 04, 2021, 01:38:02 AM »
Gary -
This is looking brilliant!   Look forward to more progress reports
« Reply #143 on: May 04, 2021, 04:00:46 AM »
Absolutely beautiful work, Gary! That is so neat and detailed, I love it! Regards, Marc.
Offline Cazadoor
« Reply #144 on: May 04, 2021, 05:05:46 AM »
Beautiful, this model looks great.
« Reply #145 on: May 04, 2021, 05:10:53 AM »
Gary, that will be another stunner of your work! Beautiful :-*
« Reply #146 on: May 04, 2021, 05:27:07 AM »
Terrific work, Gary. The paint job is so beautiful.
Bye, Manni
« Reply #147 on: May 04, 2021, 10:13:38 PM »
Love it Gary ! I can only hope that my Eduard kit turns out this nice . You are making wonderful progress on this . For the ez-line did you use the fine or heavy one ?
« Reply #148 on: May 05, 2021, 06:47:10 AM »
Thanks for that Alexis - I used the "Fine" grade of EZ-Line. I have used the Uschi stuff once in a while for previous projects, which is thinner, but needed the slightly heavier grade for this one.
« Reply #149 on: May 05, 2021, 07:53:57 AM »
Thanks Gary .
I have EZ-line heavy and I don't like it at all for anything doing rigging so I just don't use it and I have a full spool of it . I do use the Uschi line fine and standard for 48 and 32 scale sometimes . Rather use mono line ....
