After experimenting with thin plastic card, decal, card, metal foil etc, I finally decided on this approach to represent the full length inserts between twin flying and landing wires.
Basically I used kitchen baking parchment paper.
The reasons being it's very thin and is easily positioned and secured to the rigging lines using PVA adhesive, which also gives you time to reposition if necessary.
With the model fully rigged and the lines as taut:
Strips of baking parchment paper were cut to length and width (span) of the twin rigging wires.
PVA adhesive was brushed onto the rigging wires and one face of the strip.
The strip was laid onto the rigging wires and positioned to span and align with the wires.
More PVA adhesive was brushed over both sides of the applied strip and lines.
The thin paper self-grips onto the wires and adhesive.
The PVA adhesive not only secures the 'inserts' in position, but also seals the paper, ready for painting.
This method gives a smoother and flatter surface than other methods I tried.
The shots below show the strips that still need painting etc to finish them off
The next step will be to brush paint the rigging with the appropriate and thinned acrylic paint.
Lastly will be to apply thin white decal strips to represent the wrapping bands around the lines.
Having spent three day on this, I'm hoping the end result justifies the time spent - we'll see,
