Author Topic: 1:32nd scale - Ansaldo A.1 'Balilla'  (Read 25127 times)
Re: 1:32nd scale - Ansaldo A.1 'Balilla'
« Reply #105 on: January 25, 2021, 01:01:45 AM »
I've now fully rigged the wings.
This includes 'twin' flying and landing wires, cabane and interplane incidence wires and two bracing wires from the upper wing into the engine bay.
The only wires not fully connected are the two drift wires from the rear spar of the upper wing.
To avoid damaging them, they will be connected to the radiator area later in the build.
For the same reason, the moveable aileron control levers in the upper wing will be connected to their control rods later in the build.
Now it's onto completing the tail unit before tackling the inserts between the flying and landing wires,
Offline Dave Brewer
« Reply #106 on: January 25, 2021, 09:13:50 AM »
It's looking absolutely magnificent Mike, thanks for the update,
Dave.
Offline Edo
« Reply #107 on: January 25, 2021, 04:30:40 PM »
yes! beautiful indeed!
ciao
edo
Offline Kamil Zoszak
« Reply #108 on: January 25, 2021, 05:02:38 PM »
Those Italian planes are mostly beautifull
« Reply #109 on: January 26, 2021, 07:05:18 AM »
The tail unit is rigged now.
Twin bracing wires, rudder control line and elevator hinges.
Also added the 'metal' retaining strap at the rear of the fuselage at the tail plane leading edge,
« Reply #110 on: January 26, 2021, 07:29:22 AM »
Great updates, she's coming beautiful.
« Reply #111 on: January 26, 2021, 07:42:24 AM »
The rigging looks Terrific Mike. I am glad that wing went on without a hitch! Lovely aircraft and Model.
« Reply #112 on: January 26, 2021, 08:35:38 PM »
Hi Rich,
Yes this is one of the few models I've built where the upper wing fits so positively.
The square ends to the struts and their reinforcing steel rods makes for a firm, almost 'click' fit into their wing recesses,
« Reply #113 on: January 27, 2021, 09:28:23 AM »
My last model was the Nieuport 28C.1, which has twin flying wires fitted with full length inserts.
On that model I was able to represent the inserts strips between the flying wires with plastic card strips, decaled and secured between the pairs of wires.
However on this build, the length and spread of the flying and landing wires meant that I wasn't able to hold the strips in position, as the lines were too flexible.
Therefore I'm cutting the full length insert strips, cut from 0.2 mm thick plastic card, in half and using 1.0 mm wide strips of kitchen baking foil to suspend the insert on the wires.
In this way I'm able to pinch the suspended insert between the two wires (using flat ended tweezers) and apply thin CA adhesive to track along and secure it between the wires.
The foil strips are then folded around the wires/insert and secured in position using the CA adhesive, as these will be the base for the linen wrappings.
Later I'll paint the foil strips to blend with the inserts then use thin white decal strips over the foils to represent the linen wrappings.
I think this is going to take a while as there are 16 half insert strips to fit,
« Reply #114 on: January 27, 2021, 09:51:24 AM »
I was wondering how you were going to replicate the rigging bands. Now I see. Amazing, as is your entire modeling. Chapeau bas!
Offline Edo
« Reply #115 on: January 27, 2021, 04:26:52 PM »
very clever!
and very well dine!
ciao
edo
« Reply #116 on: January 28, 2021, 12:14:17 AM »
Awesome Mike!
« Reply #117 on: January 28, 2021, 07:03:08 AM »
Clever solution to a challenging detail work.
Offline Fvdm
« Reply #118 on: January 29, 2021, 04:30:29 PM »
Great work Mike!
« Reply #119 on: January 30, 2021, 01:42:41 AM »
Just a quick note to say I've re-rigged the forward flying and landing wires as I'm trying something easier and quicker to add these infills strips.
Although my previous method worked on the Nieuport 28C.1, I had problems on this 'Balilla'.
I think it's because the twin wires on the 'Balilla' are longer and wider apart.
That and the curl on the cut plastic card strips made it extremely difficult to hold in place and secure.
I'll post on the revised method once I've moved on with it,
