Author Topic: RAF FE.2b - Baroda 15 (1/32, Wingnut Wings)  (Read 25251 times)
« on: October 28, 2020, 06:33:10 AM »
After 9 years since I built the late Fee, I am back to this amazing model of the amazing aircraft. This time I plan to build the earliest possible version, with 120hp engine, two-bladed propeller, front wheel and balcony gun mount.
I have started with the nacelle. First I cut the pilot rear plate in two and glued the halves to the nacelle halves, thus will be able to fill efficiently the seams along the cockpit rim before assembly. The treatment of the vertical joint will be much easier, feasible after the interior is assembled and painted.
Since it is the early version with pilot lockers,without the aux tank, I have also removed the fuel lines, not only from the pilot front panel but also from the truss sides. Besides this, 50+ eyelets for the interior righing have been added.
« Last Edit: November 03, 2020, 07:37:20 PM by PrzemoL »
Re: RAF FE.2b Baroda (1/32, Wingnut Wings)
« Reply #1 on: October 28, 2020, 06:42:12 AM »
Excellent start! WOW, 50 plus eyelets  ::)
Offline William Adair
« Reply #2 on: October 28, 2020, 07:43:39 AM »
I love the FE.2 series.  Can’t wait to see you get stuck in.   :D
Offline Old Man
« Reply #3 on: October 28, 2020, 02:30:53 PM »
Well, this will certainly be a treat, Sir.
Offline Nigrivender
  • Do wrong and it will be good
« Reply #4 on: October 28, 2020, 04:53:30 PM »
New 500+ program  ;D
If something can't be repaired it means it's not broken
Re: RAF FE.2b - Baroda 15 (1/32, Wingnut Wings)
« Reply #5 on: November 03, 2020, 09:51:14 AM »
Some colours on the interior bits
« Reply #6 on: November 03, 2020, 10:00:04 AM »
Awesome Przemol! I love the IP and especially the Map roller!
« Reply #7 on: November 03, 2020, 07:25:44 PM »
Lovely work on the Fee, Prze!
9 years??? Where does the time go??  :o
« Reply #8 on: November 03, 2020, 10:38:14 PM »
Great start with interior work.
« Reply #9 on: November 04, 2020, 02:35:20 AM »
Off to an excellent start with the airbrush and detail painting  :)
« Reply #10 on: November 04, 2020, 03:26:01 AM »
Lovely to see another Fee being built. There is something about this aircraft which makes it interesting - even though aesthetically it left quite a lot to be desired.
« Reply #11 on: November 04, 2020, 05:46:22 AM »
Very nice variations between different wood tones! Great work overall.
Offline Europapete
« Reply #12 on: November 04, 2020, 09:11:57 AM »
Great start there Prze, looking forward to this. Regards, Pete in RI
« Reply #13 on: November 05, 2020, 07:20:05 AM »
Thank you everyone.
More progress on the innards. Two turnbuckles in the front bays added, two more to come. Also the missing control levers and cables for the throttle and spark advance added. Basically ready for the assembly.
« Reply #14 on: November 05, 2020, 09:38:43 AM »
Great start Prze - I really like the way you have figured out how to tackle that impossible seam in the cockpit. That's great advice for when I start my late Fe2b. I really like your woodgrain on everything, and the instrument panel is spectacular.
