Author Topic: Don't get PUSHY with me !  (Read 66592 times)
Re: Don't get PUSHY with me !
« Reply #450 on: July 26, 2022, 01:57:21 AM »
Can't spot the problem... and they seem awfully small, but think of how much life and interest they will add to your beautiful model!
/F
I agree with Fredrik! The wing rigging looks Awesome!
« Reply #451 on: July 26, 2022, 05:44:33 AM »
I see no issues from here...but then I swapped fore and aft struts on my Wingnut Wings Pup  :-X
« Reply #452 on: July 26, 2022, 06:47:58 AM »
Looking very good Alexis. You are demonstrating an important fact: pushers are perfectly viable models to make! We just need a few more modellers to make them....
« Reply #453 on: July 31, 2022, 08:33:57 PM »
I missed for of the turn buckle things on the lower right hand side outer bay on the double wires . :-[
Thanks a bunch guys , adventures continue with the rigging . Engine bay area is done , booms are fixed in place . This are a major issue and still don't fit right . Even though they are same length , the mounting locals on the wings aren't and toss's one hell of a wrap which rigging will not fix . So some had to be trimmed and still not good but better to the point I'm moving on . Might be able to get more of the twist removed once the wires are finally Tension up . The wires pass throw the struts . Rigging on the tail is done as well , I used left over PE parts from Rodens 1/48 Strutter for part of the hard ware mounting brackets .
« Reply #454 on: July 31, 2022, 08:34:36 PM »
« Reply #455 on: July 31, 2022, 08:35:06 PM »
« Reply #456 on: July 31, 2022, 08:35:38 PM »
« Reply #457 on: July 31, 2022, 08:36:10 PM »
 :D
« Reply #458 on: July 31, 2022, 08:36:35 PM »
« Reply #459 on: August 01, 2022, 12:22:00 AM »
I can't see a warp Alexis! Just a beautifully built, painted, and rigged DH2  ;D
« Reply #460 on: August 01, 2022, 09:24:15 AM »
Ditto!
« Reply #461 on: August 02, 2022, 02:34:31 AM »
Lovely, Alexis -
You obviously got one better fitting the taiplane onto the booms than I did ..............
Offline Stuart Malone
« Reply #462 on: August 02, 2022, 04:28:05 AM »
The turnbuckles look great!  You are being very meticulous on this and the results are showing.  It's gonna be a stunner!
Stuart
Offline Brad Cancian
    • Brad's Models
« Reply #463 on: August 02, 2022, 03:52:50 PM »
Top shelf stuff Alexis - your hard work is paying off!
BC
« Reply #464 on: August 03, 2022, 10:53:58 AM »
Thank you very much guys for the positive feed back . I might have a bit more progress to share tomorrow if I can find time to spend in front of the bench .
My time seems to be less and less with work and a promotion on a support site , I manage 30 different groups so my plate is full .
Again thanks for the continuing support and following along  :)
Alexis , still awesome and sexy as hell !
