Author Topic: Don't get PUSHY with me !  (Read 65743 times)
Re: Don't get PUSHY with me !
« Reply #240 on: March 11, 2022, 05:40:05 AM »
Bit more done and a bit more started .
The gun is being hack up and will use bit's and bobs from the Tom Model Works set to dress up the gun . WNW gun breach is slightly better then Rodens .
The cockpit padding I wasn't to sure how to actually make this and after sending a bit of time on line , it looks like most DH-2 's had this hasmap applied so it doesn't need to be perfect . To build this up I'm using Mr surface 1000 which has gone pretty thick , but still thins with thinner . Once this is done the holding clips will be added . While the putty was out I gave the fabric corners a quick brush as well for a wrinkle effect or taunt appearance , it doesn't have to be pronounced but rather match how I did the effect on the inside of the fuselage  .
The sheets which cover wear the tail booms meet the wings , nail detail was added as well . and that is all for this up-date .
Thanks for following along  :)
« Reply #241 on: March 11, 2022, 05:40:35 AM »
« Reply #242 on: March 11, 2022, 05:40:58 AM »
Online RAGIII
« Reply #243 on: March 11, 2022, 06:02:21 AM »
Your added details like the coaming and plates at the boom attachment point are really going to make this an awesome build!
PS: I Love your Wrinkles  ::)
« Last Edit: March 11, 2022, 09:59:30 AM by RAGIII »
« Reply #244 on: March 11, 2022, 09:48:03 AM »
This is coming along very nicely Alexis.
WD
« Reply #245 on: March 12, 2022, 03:24:40 AM »
I like my wrinkles too Rick , I have work hard on them over the years  ;)
Thanks WD for following along  :)
« Reply #246 on: March 12, 2022, 04:02:29 AM »
There certainly are some very nice extra details being added here Alexis.
« Reply #247 on: March 12, 2022, 06:20:42 AM »
I agree, these little bits will add up to a standout model!
« Reply #248 on: March 13, 2022, 01:59:07 AM »
Thanks Stephen and Zac ,
Will be getting some bench time in today , kick back relax and see if I can glue my hair to the bench again !
« Reply #249 on: March 13, 2022, 10:20:00 PM »
Some lovely progress on the pusher, Alexis! The extra fine detailing makes this model very special... ATB, Marc
« Reply #250 on: March 14, 2022, 01:46:55 AM »
This is looking very special! Great work as usual!
« Reply #251 on: March 14, 2022, 10:04:01 AM »
Thanks Marc and Ian  :)
My plan on hacking up the gun didn't fair well and I really made a mess of it all and had to junk the parts . Feeling rather down on myself on not paying attention to what I was doing . It was walk away and pout . Digging through the parts bin low and behold , a WNW replacement was found ! Yippie !!!! . Being a bit more careful this time around the gun is together and awaits paint . Even found the wind screen which I thought I lost . The barrel was cut off and replaced with brass tubing .
Another detail being added is the hinge detail for the ailerons , so far the lower left side is finished . Sitting there looking at the tail parts , hinge detail was added to these parts , leaving the wings rather plan in this area . The pins are a flexible brass wire so adjustments can be made latter on .
« Reply #252 on: March 14, 2022, 10:05:05 AM »
There will be more details for the wings to come  ;)
Online RAGIII
« Reply #253 on: March 14, 2022, 11:26:55 PM »
Nice progress Alexis! That Lewis Gun is beautiful!
« Reply #254 on: March 15, 2022, 03:18:13 AM »
Nice work, Alexis.  ;)
