Author Topic: British Roundel Question  (Read 1253 times)
Offline fredjocko
« on: August 29, 2020, 12:54:32 AM »
I think I'm getting close to understanding this, I probably should have paid more attention in geometry or maybe algebra 2... If I understand this correctly, using the ratio 1-3-5 for a WWI roundel and the roundel is the diameter is 78mm, the dimensions would be 15.6-46.8-78 (16-47-78)? I'm presuming the red is the one, the white is the 3, and the blue is the 5
Offline Europapete
Re: British Roundel Question
« Reply #1 on: August 29, 2020, 11:52:39 PM »
I believe so, yes.
« Reply #2 on: October 05, 2020, 03:21:27 PM »
Sounds correct!
If you're planning to make masks or your own decals, I would suggest doing some more maths based on inches. I usually assume that the British went for an even number of inches. Sometimes that produces better figures, apart from possibly being more correct.
In this case, assuming it 1/32 scale, it doesn't really make a difference though.
