Author Topic: Eduard 1/48 Bristol F.2b  (Read 8865 times)
Re: Eduard 1/48 Bristol F.2b
« Reply #15 on: September 05, 2020, 06:34:50 AM »
Thanks for the support! I had a bad time for a while and it was mostly connected to attaching the upper wing. In the end I won over the struts and rigging is progressing slowly... maybe a picture or two tomorrow.
« Reply #16 on: September 05, 2020, 11:14:56 PM »
Looking forward on seeing how she looks with the wing fitted .  :)
« Reply #17 on: September 06, 2020, 04:20:59 AM »
The mating of upper and lower wings is one thing that WNW perfected. I hope future kits by any company, in all scales,  have learned the lesson of positive strut location! I know these older kits can be challenging. Looking forward to your progress!
« Reply #18 on: September 06, 2020, 06:20:07 AM »
Thanks Terri and Rick!
I guess there could be something like experience that would help in attaching top wings, but this was probably pure luck! Eduard's struts aren't that bad, but they sure don't just fall into place either. Finally I simply superglued the cabane struts in a way that looked ok and then I attached the top wing to those and finally I took the rest of the struts and superglued them into place as well. But, like I said, probably pure luck!  :P :P :P
Some pictures... nothing much to say apart from that the first ones show the upper wing attached but no rigging done and then the last ones show all of the wires done. Next up, tomorrow possibly, would be control wires. Ohh, if you look closely you'll see that I carved a hole in each lower wing, close to the outer struts and attached the control wires running from the fuselage. Thanks again sp for your assistance! Frank, your build will come in handy for the control wires... so thank you again but in advance!
« Reply #19 on: September 06, 2020, 06:52:38 AM »
Stunning Fredrik!
I love that muted paint mask work. Spot on.
I find top wing attachments really tricky!
« Reply #20 on: September 06, 2020, 08:20:39 AM »
In Spite of any difficulties in mounting the upper wing your Bristol looks great! The rigging is looking superb. Excellent results.
« Reply #21 on: September 06, 2020, 09:18:17 AM »
Whatever issues you had , you overcame that hurdle wonderfully ! An excellent start on the rigging as well . How are you doing the double wires ?
« Reply #22 on: September 07, 2020, 12:01:39 AM »
Very nice color selection! This bird will look beautiful.
« Reply #23 on: September 07, 2020, 06:50:02 AM »
Stunning Fredrik!
Thanks Guy!
Yes I quite like the colours and their intensity, or lack thereof. I used Mr Paint's semi matte clear and it gave a nice look.
/F
« Reply #24 on: September 07, 2020, 06:55:59 AM »
Thanks Rick, Terri and Frank! You three must be among the very top of positive forum commentators!
Terri; The double wires are simply two single wires. Two holes drilled as parallel to eachother as I could at both ends and then the normal eyelet and tubing approach.
Take care!
« Last Edit: September 08, 2020, 05:40:34 AM by FAf »
« Reply #25 on: September 09, 2020, 06:43:18 AM »
Hi Fredrik, I've missed some superb builds whilst away for a month. This is looking stunning, your usual immaculate standard!
« Reply #26 on: September 09, 2020, 10:23:31 AM »
Thanks Fredrik  :)
Offline Early Bird Fan
« Reply #27 on: September 09, 2020, 04:48:56 PM »
the paint work and the build look fantastic, you guys make it look so easy   ::) :D
« Reply #28 on: September 09, 2020, 04:58:38 PM »
Hi Fredrik
You are a braver man than me, tackling a double bay biplane top wing in 1/48 scale. I find top wings daunting on every model and follow the same process as you- cabane struts first then the outer struts with fingers crossed and tube of super glue gel to hand.
Your Bristol Fighter looks really nice. I always feel a model starts to look like it's on the road to completion when the undercarriage is added and the top wing glued in place and aligned.
Great build!
« Reply #29 on: September 09, 2020, 06:50:33 PM »
Very fine work all around! Colours and rigging make the job!  :)
