Author Topic: Wingnut Wings 1/32 Albatros D.Va - COMPLETED!  (Read 35669 times)
Offline William Adair
Re: Wingnut Wings 1/32 Albatros D.Va
« Reply #90 on: October 03, 2020, 09:46:01 PM »
That's astonishing.  You could stop any time, and it would still be the nicest Albatros I've ever seen!   :D
« Reply #91 on: October 03, 2020, 10:20:08 PM »
The tank looks awesome as does all of the rest of the piping and added detail in the engine compartment! Continuing to be an outstanding build!
« Reply #92 on: October 03, 2020, 10:47:19 PM »
« Reply #93 on: October 05, 2020, 12:00:05 AM »
Very nice work!!
Offline petrov27
« Reply #94 on: October 05, 2020, 06:38:08 AM »
Looking very nice - just a really great colour scheme choice
-Patrick
Offline eclarson
« Reply #95 on: October 09, 2020, 03:58:00 AM »
A model within a model - presenting one completed Daimler-Mercedes D.IIIa engine. Taurus Models timing gear, valve springs, spark plugs, and priming cups were added. The ignition wires are Uschi elastic thread and the wire guide tubes are 0.8mm Albion aluminum micro-tubing.
In keeping with model's generally clean appearance, weathering of the engine was kept to a minimum.  AMMO Mig, AK Interactive, and home-brewed oil washes were used for detail highlights and subtle grubbiness.
The last two photos show the engine placed in position to check general fit and alignment along with the oil tank. When permanently installed additional plumbing and control linkages will be added. Also visible are the cowling cover panel latches, made from spare HGW PE eyelets and polyimide micro-tubing, added to the small triangular plates along the fuselage edges, as the panels will be left off the completed model.
Eric
Offline smperry
« Reply #96 on: October 09, 2020, 04:54:40 AM »
Beautiful engine! How loud is it? Will your wife let you run it in the house?
sp
« Reply #97 on: October 09, 2020, 05:01:30 AM »
   Magnificent engine Eric! Your Taurus additions are remarkably "clean" and the overall detail level really matches the beautiful model you've rendered, this is outstanding quality of work. I'm looking forward to the presentation of the completed Build, she's a winner!
« Reply #98 on: October 09, 2020, 05:43:48 AM »
Spectacular work on the Engine. It is absolutely Amazing!
Offline eclarson
« Reply #99 on: October 09, 2020, 06:22:52 AM »
sp
Thank you!  Hehe...in 1/32 scale it's not too loud.   She'd be more unhappy with the fumes.   ;D
Eric
« Reply #100 on: October 09, 2020, 06:24:51 AM »
I agree with the others, fantastic looking engine and very neatly built!
Offline Pup7309
« Reply #101 on: October 09, 2020, 11:09:09 AM »
I’m not into engines per se but that really is the gem in your DV crown. Daz
‘Not all who wander are lost‘
Offline Europapete
« Reply #102 on: October 09, 2020, 11:35:20 AM »
Weeeellllll...........the tappet clearances are too large, tighten them up a bit.
« Reply #103 on: October 10, 2020, 10:47:28 PM »
Beautiful work on the engine Eric  :)
Offline Umlaufmotor
« Reply #104 on: October 10, 2020, 11:50:58 PM »
At this point I have really realized this thread.
@eclarson
A very nice engine. Fine details like overflow pipes at the two carburetor float chambers, "Zisch-Hähne" on all six cylinders and the copper material shimmering through at the intake manifolds.
Also the Fasterners on the fuselage to fix the Engine-hood.
The cockpit is also excellently and convincingly built - the rear wall made of fabric, holding chain for the ignition key, the fuel distributors - all very well implemented. Very good the implementation of the fabric-wrapped Tail-skid
Bravo!  ;)
Just one remark:
Don't forget the two MG mounts (in the cockpit).
Paint the cast-on backs of the MG's in Gun-color .
Servus
Bertl
