Author Topic: Wingnut Wings 1/32 Albatros D.Va - COMPLETED!  (Read 35671 times)
Re: Wingnut Wings 1/32 Albatros D.Va
« Reply #60 on: September 08, 2020, 10:12:07 PM »
Eric,
    Very clever trick with the poster putty, I've used the same technique with fresh "blu-tac" and the RB "parts pencil" works nearly as well. This is a beautiful model even at this early stage, and your "woodwork" is exceptional! A pleasure to follow your progress here, lovely work!
« Reply #61 on: September 09, 2020, 02:19:03 AM »
The engine should be an outstanding addition to your already beautiful Model! Nice touch with the poster putty!
« Reply #62 on: September 09, 2020, 10:39:49 AM »
Those details are really going to make the engine pop ! Even with my glasses I have a hard time seeing them .
« Reply #63 on: September 09, 2020, 11:53:57 AM »
Beautiful work on the paint/wood finish and nice engineering on the motor
Offline Early Bird Fan
« Reply #64 on: September 09, 2020, 04:39:04 PM »
stunning bit of wood painting, looking forward to seeing the rest of it
Offline eclarson
« Reply #65 on: September 12, 2020, 12:04:03 AM »
Applying the HGW Nail Head decals - slow work, especially with the recommended 6-8 hour wait before peeling off the carrier film - but so worth it!
Eric
« Reply #66 on: September 12, 2020, 01:19:37 AM »
The nail heads do add to the overall look! I really like how this one is turning out!
« Reply #67 on: September 12, 2020, 01:27:19 AM »
this just gets better and better, loving the look of that fuselage
« Reply #68 on: September 12, 2020, 02:02:11 AM »
You've nailed it!  ::)
Offline Pup7309
« Reply #69 on: September 23, 2020, 09:41:31 PM »
 ;D Yes you have!
‘Not all who wander are lost‘
Offline eclarson
« Reply #70 on: September 26, 2020, 12:19:26 PM »
Just finished the most nerve wracking thing I've ever done on a model.  Thanks to Pheon's one-piece fuselage sash decal not coming close to fitting, I had to resort to masking and painting the white and red bands over the finished wood grain and nail head decals!
Fortunately, Pheon also provided separate badges.  I later noticed one of the badges on the sash decal was printed reversed whereas the individual ones are correct. Several coats of Tamiya Clear Gloss, allowed to cure for a week, sealed the wood grain and nail heads so I figured masking with Tamiya tape would be low-risk. I used strips of their 3.0mm "tape for curves" to outline the bands then extended the masking with regular Tamiya tape and plastic wrap. Removing the tape went well until the last piece which lifted a small area of the wood right down to the bare plastic. There must have been some contaminant on the plastic, like finger oil, before the first coat of primer was applied.
But if it had to happen, it couldn't have happened in a better spot as it will be covered by the badge decal. Tamiya Clear was applied over the "wound" to seal it.  After the band's paint has cured for a day or so, another gloss clear coat will be sprayed on prior to applying the badge decals.
Finally, here's a closeup of the tail showing the skid details.  I wrapped the center portion with a strip of thin parchment paper, coated with white glue and Future, to replicate how the real one was wrapped with linen strips for reinforcement.  The exposed part was given my usual oil paint wood grain treatment.  The steel end cap was painted Vallejo Gun Metal.
Eric
Offline smperry
« Reply #71 on: September 26, 2020, 09:25:29 PM »
Beautiful work Eric. Still, that pull up had to tick you off, so glad it will be hidden.
sp
« Reply #72 on: September 26, 2020, 09:34:37 PM »
Superb work Eric! I do like stripes/bands and yours are Top Notch. This is turning into one of the prettiest Albatros Models I have seen.
« Reply #73 on: September 26, 2020, 09:59:55 PM »
Beautiful work Eric on the fuselage  :)
Not sure what you mean by ..." 6-8 hours before pulling the backing off " ? Never heard of having to do this to decals before .
« Reply #74 on: September 26, 2020, 10:32:53 PM »
Looking absolutely stunning, shame about the damage but at least it's gonna be hidden #modelgoals 😎👍
