Author Topic: Sopwith Triplane "Black Maria", Eduard 1/48, Update outdoor photos  (Read 12328 times)
Offline Radarman
Re: Sopwith Triplane "Black Maria", Eduard 1/48
« Reply #15 on: August 18, 2020, 10:51:50 PM »
Frank,
I have enjoyed this build from the start and the result is fantastic.
        Thanks for sharing your skills,
        Kevin
« Reply #16 on: August 19, 2020, 03:38:41 AM »
Thank you Kevin, also for your continued support in the build thread!
Fortunately I started to build these flying wire entanglements quite late, because when this kit was released, these great accessories from Small Stuff and Gaspatch were not available. But in retrospect it was hard to find the old kits - I found this triplane kit in Italy.
Offline jeroen_R90S
« Reply #17 on: August 19, 2020, 07:36:17 PM »
Following your build was truly a pleasure. I was more amazed with each update! This is a Masterful Build in all aspects! Brilliant work Frank!
One thing that catches my eye somehow is that the fuselage behind the cockpit on the Eduard model seems less rounded (flatter) than in the picture of the real one. Not meant as criticism, just something that I noticed (and would be hard to correct, although for you it seems noting is impossible!  8)
Jeroen
« Reply #18 on: August 20, 2020, 03:24:03 AM »
Thank you Jeroen!
That is a interesting question, so I cut a paper template from the section D-D (end of the cockpit cut out) of the Datafile drawing and hold it to the model - perfect match. So Eduard got it right according to the drawing. May be the drawing is wrong?
Could also be a optical effect, I can't reach the same camera position with my lens.
Offline jeroen_R90S
« Reply #19 on: August 20, 2020, 05:19:29 AM »
Could be an optical effect, too -the original has a pronounced reflection on the edge where the panel around the cockpit changes into fabric, which shows it's curve very well -perhaps too well?
It would be interesting to see how the Wingnuts model relates to a scaled-up drawing :) Or am I being obsessed now?  ;D ;D
« Reply #20 on: August 20, 2020, 09:45:56 AM »
Very nicely done.  I especially like the way you highlighted the wing ribbing, almost a translucent effect.  As mentioned too the color is a real eye catcher as well, like the shade of PC-12 you have.  Overall a very outstanding build.
Offline Dwaynewilly
« Reply #21 on: August 20, 2020, 01:17:31 PM »
You made that old Eduard kit shine. Nice work indeed.
Dwayne
« Reply #22 on: August 21, 2020, 04:22:41 AM »
Dwayne
Ditto this and all the above compliments !
« Reply #23 on: August 22, 2020, 08:29:00 PM »
Thank you Mark, Dwayne and Ed!
I used a lightning tent for the pictures but I do not like the reflection of the PC12 to the lower surfaces above. I really must try to take some outdoor shots.
Sopwith Triplane "Black Maria", Eduard 1/48, Outdoor photos
« Reply #24 on: August 23, 2020, 12:55:04 AM »
Today I took outdoor shots before it started raining. Enjoy!
Offline jeroen_R90S
Re: Sopwith Triplane "Black Maria", Eduard 1/48, Update outdoor photos
« Reply #25 on: August 26, 2020, 07:44:48 PM »
Even prettier this way :)
« Reply #26 on: September 03, 2020, 03:07:33 PM »
Love the plane and new photos, Frank!  Very nice!
« Reply #27 on: September 03, 2020, 04:45:41 PM »
Why are you posting pictures of a real full size aeroplane here?
« Reply #28 on: September 03, 2020, 07:01:56 PM »
I want to jump in and fly her Frank!
« Reply #29 on: September 04, 2020, 10:46:38 PM »
Thank you Jeroen, Gaz, Sandy and Guy!
Because this is one of my scaled down originals :D See my signature below.
Guy, I can only allow that with a valid type rating :P
