Under Construction
Checker Time , Sopwith Camel
Pages:
6
7
8
9
15
Topic: Checker Time , Sopwith Camel (Read 31183 times)
Love the self
Re: Checker Time , Sopwith Camel
Reply #90 on:
September 22, 2020, 09:59:06 AM »
Quote from: RAGIII on September 21, 2020, 11:50:16 PM
Looks great Terri! Are those belts from the kit? The are quite impressive!
Hi Rick , yes the belts are from the kit , thanks for checking in
jeroen_R90S
Reply #91 on:
September 22, 2020, 04:38:30 PM »
Nice work, Terri! The instrument panel looks good
Love the self
Reply #92 on:
September 27, 2020, 10:48:30 AM »
Thanks Jeroen
Work has continued one this with a wash being applied and sealed with a matt coat minus the instrument panel and the metal panels .
The lower wing didn't fit and some curving and trimming was needed to get it in place . I also had to remove the vent side panels on the inner firewall , this press up on the rudder bar with is another fit issue altogether . The carb pipe isn't long to span across the fuselage into it's mounting holes , same with the spent shell shouts , but I can make this work . It is easier to mount the fire wall to the upper decking , lines up better with no gaps . All other parts are removed and ready for clean up .
Reply #93 on:
September 27, 2020, 12:07:05 PM »
Looking good Terri but Damn, You deserve a NO Problem build!
Monty
Reply #94 on:
September 27, 2020, 10:30:20 PM »
Very nice Camel build, and great detail! A lesson in modelling... Regards, Marc.
Love the self
Reply #95 on:
September 28, 2020, 02:03:11 AM »
Thanks Rick and Marc
Yes , it would be nice at this point to have a trouble free build , but these fit issues are very minor and have been fix . I added small bits of round stock to the end of the card intakes to fill the gap . Once those a dried this stage can get glued up and start with the seams .
Love the self
Reply #96 on:
September 28, 2020, 08:24:37 AM »
Instrument panel is now in place . Extending the carb tube did the trick and lines up ! Hey!!!
I'm a little disappointed on the Vickers breaches , the are very very simple even with the PE cocking handles they are still very , very basic .
Radarman
Reply #97 on:
September 28, 2020, 09:26:23 AM »
Looking good Terri. I wonder if some these short comings are the reason Eduard are or were planning to produce a new mold Sopwith Camel? Anyway, it’s coming along great.
Kevin
Reply #98 on:
September 28, 2020, 09:36:26 AM »
I P looks great in place Terri.
Love the self
Reply #99 on:
September 28, 2020, 09:30:49 PM »
Thanks Kevin and Rick , once the top decking is fixed in place the rest should go at faster pace once the painting starts .
Love the self
Reply #100 on:
September 29, 2020, 11:32:09 AM »
Tonight I work on getting the top decking and firewall in place and test fitted the cowl and it fits ! I don't have to worry about sanding , filling , filling , cursing . Can move onto taking care of the seams
GazzaS
Reply #101 on:
September 29, 2020, 05:05:08 PM »
Nice progress, Terri! It's always good when a kit allows you to minimize cursing.
There are only two states to be in: Queensland and blotto.
Love the self
Reply #102 on:
September 30, 2020, 09:44:56 AM »
yes it is
Thanks Gaz !
Reply #103 on:
September 30, 2020, 11:18:53 AM »
Great Progress T!
Love the self
Reply #104 on:
September 30, 2020, 09:20:31 PM »
Thanks Rick
Pages:
6
7
8
9
15
Under Construction
