Author Topic: Checker Time , Sopwith Camel  (Read 30978 times)
Re: Checker Time , Sopwith Camel
« Reply #105 on: October 10, 2020, 11:36:31 AM »
Seems are filled and sanded , few more items to clean up ( Struts ) and I't ready for primer !
« Reply #106 on: October 10, 2020, 11:36:59 AM »
and the under side ...
Offline Radarman
« Reply #107 on: October 10, 2020, 02:41:26 PM »
Terri,
What is your primer of choice?
                                   Kevin
« Reply #108 on: October 10, 2020, 10:39:47 PM »
It all depends Kevin ,
I'll use either a light grey or a neutral grey sometimes even white using Tamiya paints cut with lacquer thinner . Nothing fancy really . I try to keep things simple , I cause myself a enough frustration during a build .
« Reply #109 on: October 10, 2020, 11:34:57 PM »
Looking Great Terri. Your approach to primer sounds similar to mine!
« Reply #110 on: October 11, 2020, 07:09:30 AM »
Thanks Rick , rest of the parts are cleaned up just have a few PE parts to add and drill the rigging holes . Paint can commence  :)
« Reply #111 on: October 12, 2020, 03:59:48 AM »
Looking forward to seeing top coats going on to this one Terri. It is going to be a very interesting markings scheme.
« Reply #112 on: October 12, 2020, 04:09:42 AM »
Wow! Quick and exemplary work on this one, Terri! Well done!
« Reply #113 on: October 12, 2020, 12:13:03 PM »
Thanks Stephen and Marc ,
Turned out be more PE then what I thought and with a nap this afternoon I didn't make it to primer , but everything is ready for tomorrow .
I had the flight controls on the main wings in the wrong place and got them changed around as they should be . The inspection windows are very plain ( no pulley detail ) , They are a prefect fit so that made my life easier !
« Reply #114 on: October 12, 2020, 11:44:15 PM »
I am looking forward to the painting process T!
« Reply #115 on: October 13, 2020, 02:08:23 AM »
This one is certainly moving quickly now Terri. Like Rick I am looking forward to seeing some paint going on to this.
« Reply #116 on: October 13, 2020, 11:32:57 AM »
Thank-you Rick and Stephen , painting has started !
The white has been sprayed and once fully dried it can get masked off for the next shade .
Offline Radarman
« Reply #117 on: October 13, 2020, 01:14:29 PM »
Looking good Terri!
                       Kevin
Offline jeroen_R90S
« Reply #118 on: October 13, 2020, 06:08:23 PM »
Going in the right direction, looking good so far! :)
« Reply #119 on: October 14, 2020, 12:18:05 AM »
Thanks Kevin and Jeroen , more airbrushing today  ;)
