Author Topic: VOISIN 10 LAR 1:48  (Read 4114 times)
Offline Saso Krasovec
VOISIN 10 LAR 1:48
« on: November 30, 2012, 06:17:04 PM »
Kit: Hi Tech (1:48)
Here are some photos of my VOISIN 10 LAR modell. The kit is injection moulded and has some PU, PE and white metal parts but still need a lot of scratch. I used photographs throu the Internet. Allso, I photographed beautifull restored front – cockpit in Le Bourget, Paris, France.
Hi Tech kit is only for base, for further detailing I used different plastic sheets, brass and cooper wires, thin metal foil and different tickness of fishing line. The model was painted with REVELL 09 matt color, for weatherig I used pastels. Finally was model coated with coat of Modell Master Custom semi glosslacquer.
Saso Krasovec
http://s1306.beta.photobucket.com/user/sasokrasovec/library/VOISIN%2010%20LAR
Re: VOISIN 10 LAR 1:48
« Reply #1 on: November 30, 2012, 09:59:54 PM »
Saso, you are a sublimely talented craftsman and modeler!  We clearly have another Star here at the Forum.   ;)  Great work.  Thanks so much for sharing this beautiful model.
I have taken note of your impressive and substantial jigs.  Can you explain how you design and construct those?  Thanks!
« Reply #2 on: December 01, 2012, 12:07:12 AM »
Absolutely stunning Saso, beautiful work!
« Reply #3 on: December 01, 2012, 02:42:28 AM »
Truly brilliant, Saso.  She's absolutely gorgeous.  Thank you for posting such detailed progress photos.  I have this kit and with these photos as a guide, I will no longer be afraid to start it.  Did you use the kit tail boom or did you fabricate a new one?
« Reply #4 on: December 01, 2012, 03:27:38 AM »
Outstanding workmanship Saso!!
« Reply #5 on: December 01, 2012, 01:34:56 PM »
Stunning work! absolutely teriffic craftmanship.
« Reply #6 on: December 01, 2012, 10:36:50 PM »
  Saso,
Now that's truly an amazing example of Master Class level craftsmanship and skill my friend. Congratulations and Well Done.
Offline Brad Cancian
    • Brad's Models
« Reply #7 on: December 02, 2012, 12:41:33 PM »
Most impressive!  :o
Offline Whiteknuckles
« Reply #8 on: December 02, 2012, 12:58:19 PM »
Excellent work Saso, impressive build and excellently done ;)
Eternal Apprentice
« Reply #9 on: December 03, 2012, 05:19:05 PM »
Thanks all!
Jigs: the kit includes small side profil that I used to made drawings in computer with CAD program, print the drawings on selfadhesive label. I cut parts from plywood and cement with white glue on hard base.
Tail boom: 1 mm brass rod; "wooden" struts: 0'5 mm steel rod cemented in the plastic kit strut and then thined down; undercarriage and other struts: 0'5 and 0'8 mm brass rod. All plastic struts are too thick.
Saso Krasovec
