Author Topic: Eduards Roland C.II  (Read 10795 times)
Offline Old Man
Re: Eduards Roland C.II
« Reply #45 on: July 03, 2020, 12:41:04 PM »
Shaping up very nicely, Ma'am.
What is Flory dark dirt? It seems to give a good understated effect.
« Reply #46 on: July 03, 2020, 01:38:03 PM »
Hi Oldman , glad to have you checking in  :)
Flory washes are clay based . It is a mixed of very fine clay power with water and soap bas to it . Apply to the model like any other wash . Let it dry ( dries fast ) and wipe away with a damp cloth with water . Works best over a gloss surface , not so good on flat coats but interesting effect can be had though .
I have their full range of washes and pigmets and I love their sanding sticks !
https://www.florymodels.org/washes
Offline Old Man
« Reply #47 on: July 03, 2020, 02:20:51 PM »
Thank you, Ma'am!
I will certainly look into that when I am next buying supplies. I do a lot of panel-line on WWII era stuff with a pencil, which will stay black if gone over with matte coat (otherwise it can glint silver at certain angles, or with dilute paint applied and wiped immediate. I have taken a shot at an oil wash, and it seemed a lot of work for the result. What seems attractive about this is the claim it can go over a matte surface.
« Reply #48 on: July 04, 2020, 07:17:16 AM »
Beuatiful Painting Terri! I love the subtle wash around the windows. Looks great with the Markings!
« Reply #49 on: July 05, 2020, 02:07:11 AM »
You are welcome Oldman , hope they work well for you if you choose to pick some up .
Thanks Rick ,
I finished off the guns last night so I can start painting and weathering them up and finishing a few more bits .
« Last Edit: July 05, 2020, 11:42:31 AM by Terri »
« Reply #50 on: July 05, 2020, 07:55:21 AM »
Nice looking paint, Terri.  That flory wash really helps with the mono scheme.
« Reply #51 on: July 05, 2020, 12:02:39 PM »
Hi Gary , yes it sure does help with mono scheme giving it a bit more life . The final weathering is yet to come so I'm hoping that I don't mess it up and over do it .
The MG's are put together as well , but I went with a different plan . Going through the spare gun bin I found a resin set . Have no idea who's they are but the breaches came in get use . The PE barrels are also from the bin while the sights are spare PE . Exhaust just needs a flat coat now . I also added seatbelts .
« Reply #52 on: July 05, 2020, 12:03:09 PM »
« Reply #53 on: July 05, 2020, 12:03:45 PM »
« Reply #54 on: July 05, 2020, 12:04:14 PM »
« Reply #55 on: July 05, 2020, 02:41:20 PM »
Coming on greatly, T!
« Reply #56 on: July 06, 2020, 02:39:51 AM »
You seem to have a whole arsenal of guns at the moment!
« Reply #57 on: July 06, 2020, 09:02:08 AM »
Thanks Gary and Ken  8)
Ken , I like to be well armed  ;)
So with yet another day of rain time was spent relaxing in front of the bench while listening to a band called Yello  :) Love these guys !
Out comes the airbrush and a coat of Vallejo clear flat . This was misted on in very light coats taking my time . I just needed enough for the chalks to bite into . While that was drying I ended up re-paint the prop . It is now set a side drying with it's clear coat awaiting the prop logo's .
With the dull coat dry out came the chalks and more weathering was added to the hinges , behind the rads . I used Tamiya pastels for the mud staining on the under side of the lower wings . Once all that was done it was seal with Vallejo satin finish and the rigging has started as well .
« Reply #58 on: July 06, 2020, 09:02:36 AM »
« Reply #59 on: July 06, 2020, 09:03:04 AM »
