Author Topic: 1:32nd scale Siemens-Schuckert D.III (Early)  (Read 26249 times)
Re: 1:32nd scale Siemens-Schuckert D.III (Early)
« Reply #120 on: July 09, 2020, 06:30:13 AM »
Sorry to hear about your disaster Mike, at least you didn't try to clamp a dropped Xacto between your legs. I have no doubt your repairs will be unnoticeable.
They say bad things happen in threes. Between you, Rick and myself, we have that covered. This seems like an ideal time to add top wings since the quota has been met :-)
sp
       Sadly it's actually "fours" with this addition. I was doing a last minute dry fit of the just completed cockpit module of that Tamiya Spitfire I've got entered in the Off Topic" Section and yes, dropped it onto a hard floor as well. Broke a longeron and it took me a good half hour to find the gun sight, all's well now but I confess to saying "fooey" (or something similar) several times! :-[ It is indeed a bad week for mishaps!
« Reply #121 on: July 09, 2020, 07:10:03 AM »
Seems I'm not alone then - but as I say 'we're modellers'  :-\
« Reply #122 on: July 09, 2020, 09:56:54 AM »
Every now and then a build will fight me hand tooth and nail and mishap after mishap , then there are ones which go perfectly no mishaps at all Sad to hear that it happen , but in the end no one will notice ...like it never happend .
« Reply #123 on: July 12, 2020, 07:30:26 AM »
Applying 1.0 mm wide 5 colour lozenge rib tape decals onto 5 colour lozenge really strains these old eyes.
However I'm getting there as the upper wing and elevator are done now.
I've still to decal the lower wings and the four ailerons,
« Reply #124 on: July 12, 2020, 07:54:24 AM »
Lozenge and Tapes are looking Excellent Mike!
« Reply #125 on: July 12, 2020, 10:31:09 AM »
Nice job on the decaling Mike  :)
« Reply #126 on: July 14, 2020, 05:29:43 AM »
Just a small update.
The wing outer 'V' struts were tubular steel covered with a Spruce wood fairing.
The fairings were then covered with the lozenge linen or in some cases, the lozenge pattern was hand painted.
I've used the same 'Aviattic' lozenge decal that used for the rib tapes.
« Reply #127 on: July 14, 2020, 08:49:33 AM »
Excellent work on covering the struts with decals. Not always easy to get them right!
Offline smperry
« Reply #128 on: July 14, 2020, 09:00:04 AM »
That had to be fiddly. You aced it though.
sp
« Reply #129 on: July 14, 2020, 07:54:32 PM »
I was sorry to read of the mishap but you have triumphed magnificently. The lozenge looks really beautiful.
« Reply #130 on: July 18, 2020, 02:21:41 AM »
I don't think I've spent as much time cutting and applying decals to any model, as I have on this one.
The upper wing/ailerons are 45 degree 5 colour lozenge ('Aviattic' ATT32019 underside, ATT32018 top surface).
The lower wings/ailerons and elevator are standard 5 colour lozenge ('Aviattic' ATT32075 underside, ATT32013 top surface).
All rib and edging tapes were cut from 'Aviattic' ATT32073.
National markings and pilots personal markings were from the ‘Pheon’ (32023) Siemens Schuckert D.III decal sheet.
I had the problem of repairing the model after I dropped it during final preparation for applying the decals.
I managed to catch it between my legs, but in the process clamped the wing tips which transformed the D.III into more of a Vought Corsair!!
I had to break off the upturned lower wings, clean up, re-pack, re-drill and re-pin then reassemble.
All in all it didn't turn out too bad.
The surfaces are gloss sealed so as not to damage the applied decals. The final finish and weathering will be done later in the build.
Offline smperry
« Reply #131 on: July 18, 2020, 02:28:17 AM »
Very nice recovery Mike. I have much the same repair to do on my Albatros, so you are quite the inspiration.
sp
« Reply #132 on: July 18, 2020, 04:23:55 AM »
Looks amazing Mike and like SP said nice recovery!
« Reply #133 on: July 20, 2020, 05:03:09 AM »
Moving along slowly.
The engine and cowl have been fitted with an 'RB Productions' 9/32nd flat rigging wire used to represent the cowl retaining strap.
Photo-etch quarter turn fasteners have been added to the main panels and wingnut fasteners to the two side and one underside access panels.
Both machine guns are on as well as the fuel tank contents gauge.
Very slight paint weathering was applied (sponged) and a light sheen sealing coat airbrushed to act as the base for dirt weathering.
Before that I need to fit and rig the undercarriage assembly so as to prevent damaging the PE fasteners on the underside access panel on the fuselage.
« Reply #134 on: July 20, 2020, 11:42:01 PM »
I missed this update until now. The cowling and MGs look amazing and using the flat rigging material for the strap is a Great idea!
