Author Topic: Sopwith Triplane 1/48, Upd 16.8.2020 Finale and a riddle again!  (Read 38813 times)
Offline smperry
Re: Sopwith Triplane 1/48, Upd 3.7.2020 seat and belts
« Reply #60 on: July 04, 2020, 10:11:07 AM »
All right Frank, just hold on a second. I gotta know how you did the seat cushion.  "I made it from Miliput." You might as well have said. "I carved it from soft balsa." Just how did you get those creases radiating from each of the indented buttons? I have been able to shape a cushion and even poke indents in one, but never have I gotten the radiating creases. It really makes the whole seat even with the wide seat belt covering a good portion of it.
Before I forget, the other details are just first rate too. I especially like the pump and fuel gauge.
sp
« Reply #61 on: July 05, 2020, 02:11:35 AM »
That cushion looks nice and comfy  :)
« Reply #62 on: July 05, 2020, 03:43:26 AM »
" I gotta know how you did the seat cushion.  "I made it from Miliput." You might as well have said. "I carved it from soft balsa." Just how did you get those creases radiating from each of the indented buttons? "
He's a magician.
Offline smperry
« Reply #63 on: July 05, 2020, 03:52:03 AM »
Oh. OK. That 'splains it.
sp
« Reply #64 on: July 05, 2020, 05:48:18 AM »
Thank you sp and Terri for your continued support!
Ken ;D ;D 8)
Hmm, you know my solution is patented? Are you able to pay the license fees? ;)
I guess you know that epoxy putty?
So I formed a thin flat piece after kneaded both components. With a cutter I removed the parts, which are to big, so you get the form of the cushion. That is easy so far. But now about the surface and the buttons ...
I have great respect for the artists who use such putty to sculpt a figure! I couldn't do it, so I have to let physics work for me 8)
I also found this by chance when I built my Albatros W.4. I had a very thin foil of a bag underneath (I mean really thin, e.g. a small transparent bag from the supermarket for fruits and vegetables or a garbage bag. My digital measuring slide says 0.01mm!) to not dirty my workbench. Then I also put the foil also on top and pressed the small ball of milliput flat. And I noticed that when I pressed the recesses of the buttons with a toothpick, the foil warped and creased just as the surface of the seat cushion would have done realistically. This only works if the milliput is still very soft and fresh, after half an hour, for example, it is already to hard. Let it for a moment and then remove the foil. If you do not like it, roll it to a ball and try again, a bit of experimenting is needed.
I hope, my explanation is clear enough, otherwise I will try to make pictures.
Back to the licence fee: If we ever get together, you can buy me a beer 8)
Offline smperry
« Reply #65 on: July 05, 2020, 06:58:31 AM »
Hey, Hey, You're on for the beer Frank.
That was the only way I thought it could be done by covering the cushion and the poking the indents. Only thing I am bot too clear on is the foil you describe, Al foil or that silver mylar looking stuff?
Thanks for taking the time to explain.
sp
« Reply #66 on: July 05, 2020, 08:01:52 AM »
That's really nice detail work, Frank!
« Reply #67 on: July 07, 2020, 05:36:12 AM »
« Last Edit: May 31, 2022, 01:24:23 AM by Bughunter »
Offline smperry
« Reply #68 on: July 07, 2020, 08:40:33 AM »
Ah,, I see. Thanks Frank. Now I have to start a new model to try out you seat cushion technique.
sp
Sopwith Triplane 1/48, Upd 8.7.2020 Gun outlets
« Reply #69 on: July 09, 2020, 06:38:43 AM »
« Last Edit: May 31, 2022, 01:24:30 AM by Bughunter »
Re: Sopwith Triplane 1/48, Upd 8.7.2020 Gun outlets
« Reply #70 on: July 09, 2020, 07:29:47 AM »
Just amazing! You even used the right number of layers for the rudder pedal, doesn't matter if it is never seen again. We've all seen it and you had great fun making it. You're adding more details than I had in my 1/32 WNW kit. This is amazing modelling, thanks for keeping us all entertained!
« Reply #71 on: July 09, 2020, 08:26:07 AM »
Are you kidding me!  Those inner details look fab, Frank!  Those brass bezels...  be still my beating heart!
« Reply #72 on: July 09, 2020, 09:01:15 AM »
Eye candy !
Excellent work Frank , shame that the rudder bar can't be seen , but it is there  ;)
« Reply #73 on: July 09, 2020, 10:26:32 AM »
Rudder bar, IP, and all of the other details are Amazing Frank! Brilliant as always!
Sopwith Triplane 1/48, Upd 10.7.2020 Tail skid
« Reply #74 on: July 11, 2020, 03:08:03 AM »
« Last Edit: May 31, 2022, 01:24:37 AM by Bughunter »
