Author Topic: Sopwith Triplane 1/48, Upd 16.8.2020 Finale and a riddle again!  (Read 38798 times)
Re: Sopwith Triplane 1/48, Upd 24.5.2020 Clerget engine
« Reply #30 on: May 25, 2020, 05:18:05 AM »
I like the results of your afternoon session very much Frank. That Small Stuff engine is amazingly detailed and you've certainly done it justice. Definitely EPIC so far! ;)
« Reply #31 on: May 26, 2020, 12:40:36 AM »
I don't think Anyone does better Engines than you Frank! Superb detailing and the painting is Magnificent!
« Reply #32 on: May 26, 2020, 01:39:10 AM »
Thank you Richie and Rick!
A Small Stuff engine come safely packed in a small Zip bag, which contains smaller bags with the parts and a folded A4 sheet with manual. This manual is enough to build the engine, but on all manual sheets is a link, which I suggest strongly to follow! It makes the build much easier and has also tips for painting. Here it is:
https://www.smallstuffmodels.com/p/buildinganengine.html
I followed it, so praise goes to Small Stuff!
Re: Sopwith Triplane 1/48, Upd 24.5.2020 Clerget engine - new pic
« Reply #33 on: May 26, 2020, 02:59:59 AM »
« Last Edit: May 31, 2022, 01:23:40 AM by Bughunter »
Online lone modeller
« Reply #34 on: May 26, 2020, 03:21:12 AM »
Lovely engine Frank. Those Small Stuff engines really are the dog's bo...ks - I have used some in the True Scale and am amazed at the amount of detail that they contain. You have painted yours to look extremely realistic and it will look very well indeed on the finished model.
Sopwith Triplane 1/48, Upd 25.5.2020 Question upper wing
« Reply #35 on: May 26, 2020, 03:31:38 AM »
Thank you Stephen!
In God's own scale the build is a bit easier because the valve rockers and cylinders was an one piece affair, at least on the type I have build for my Fokker E.V Stripdown. That was my only 72 Small Stuff engine until now.
Different subject:
The Triplane has a more square clear inspection window in the middle of the upper wing. Does anyone has a picture of the layout inside? I guess two pulleys, but I have no clue how.
Thanks!
Re: Sopwith Triplane 1/48, Upd 25.5.2020 Question upper wing
« Reply #36 on: May 26, 2020, 03:53:25 AM »
Hi Frank, onthe Vintage Aviator website there is a walkaround of a replica of the very air frame you are modelling. Their site is a bit odd as I can't copy a link or download the photos. There is a photo of the lower wing inspection window and pulley which must be similar to the top wing.
Lots of detail shots there for you to look at. If you go on my Flickr feed, I took loads of detail pictures of the Shuttleworth Triplane just before lockdown. Sadly only on a camera phone. Some might be of interest to you.
« Reply #37 on: May 26, 2020, 05:27:11 AM »
« Last Edit: May 31, 2022, 01:23:47 AM by Bughunter »
« Reply #38 on: May 26, 2020, 05:54:45 AM »
Ah, I see what you mean. Will see what's suggested on the WNW 1/32 tomorrow.
« Reply #39 on: May 27, 2020, 04:08:36 AM »
Hi Frank,
The centre window appears to just have a single wire with a turnbuckle in the middle.
Here's my WNW top centre port.
20200526_153124 by Richard Williams, on Flickr
« Reply #40 on: May 27, 2020, 07:05:34 PM »
That engine looks quite nice!
« Reply #41 on: May 28, 2020, 12:11:31 AM »
Thank you!
Richie, that picture helps a lot!
On scalemates there is a 1:16 kit of the Camel, the manual of the kit can be downloaded.
https://www.scalemates.com/kits/model-airways-ma1030-sopwith-camel-f1--158232
And inside the is a drawing showing the aileron control. Ok, here we have a wing and two ailerons more, but the principle should be the same. So I wondered, what is there in the middle below the window. Now it is clear  :)
Thank you very much!
« Reply #42 on: May 28, 2020, 12:28:15 AM »
My pleasure Frank, always good to help a fellow modeller. You have inspired me to get on with my Triplane, I'm not at your level as modeller but your exquisite work has inspired me to improve. :)
Sopwith Triplane 1/48, Upd 19.6.2020 Landing gear
« Reply #43 on: June 20, 2020, 05:45:38 AM »
« Last Edit: May 31, 2022, 01:23:56 AM by Bughunter »
Re: Sopwith Triplane 1/48, Upd 19.6.2020 Landing gear
« Reply #44 on: June 20, 2020, 06:43:20 AM »
Very neat Frank, I'm loving seeing all these scratch built modifications you do. Good to see an update on this one too. I love the triplane, such a weird but elegant aircraft.
