Author Topic: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke  (Read 192198 times)
Re: Hobby Craft 1/32nd SPAD XIII times Three: plus Aviattic Luke
« Reply #150 on: May 06, 2020, 09:36:49 AM »
Rick
You are displaying a great deal of discipline to keep all three going as closely together as you have them. Makes my head ache thinking about it  :-)
sp
I don't know about discipline but it takes one day to figure things out on the first one, then one more to do the other two  8)
« Reply #151 on: May 06, 2020, 03:54:01 PM »
Two albatrosen and now three SPAD's.  Amazing work, mate!
« Reply #152 on: May 06, 2020, 08:19:47 PM »
THanks for dropping in and the comment!
PS: The SPADS may be joined by their cousin the Nieuport 23 soon  8)
« Last Edit: May 06, 2020, 11:04:06 PM by RAGIII »
« Reply #153 on: May 06, 2020, 10:54:41 PM »
Rick, your triplets are looking very fine indeed.  This will be a learning experience for me, as I have this kit in the stash.  Carry on!
Best,
« Reply #154 on: May 06, 2020, 11:05:20 PM »
Best,
Thanks Bob. I hope you are also following Richards build and have looked through the PDF of the build by Mike Norris!
« Reply #155 on: May 06, 2020, 11:12:50 PM »
I am, and thanks for the .pdf tip Rick!
« Reply #156 on: May 06, 2020, 11:27:39 PM »
You are welcome. My builds show what can be done with basic modeling tools and skills. Mike shows what can be achieved with all of the Bells and Whistles  ;D
PS: A link to Mikes build that gives a link to the PDF: https://forum.ww1aircraftmodels.com/index.php?topic=9691.msg177205#msg177205
« Last Edit: May 07, 2020, 03:31:03 AM by RAGIII »
« Reply #157 on: May 07, 2020, 02:17:41 AM »
Super stuff Rick, an impressive rate of progress, I find getting the fuselage joined to be one of the most worrying steps. You've got this done very neatly....3 times! Definitely earned a black and tan or 1 there!
Would love to see a Nieuport up next. :)
« Reply #158 on: May 07, 2020, 03:32:30 AM »
Thanks Richie. The fuselage joints will require some filling and sanding but overall I am pleased!
« Reply #159 on: May 07, 2020, 08:52:35 AM »
Todays Progress:
1. I finished the instrument panel switches on all three upper fuselage parts.
2. I added the last instrument to the right side of one of the SPADS.
3  I began the process of rounding off and converting one of the SPADS wings to the early version
4. I carved My Very first ever strut using a Bamboo skewer. I wonder if I can get 11 more just the same ?
Offline smperry
« Reply #160 on: May 07, 2020, 10:05:01 AM »
Rick
I have used bamboo skewers for years. At the risk of telling Grandpa how to suck eggs, here are a few tips to save some hassle:
In the larger scales, only make one plank out of the the skewer, right out of the center, half the thickness of the plank on either side of the centerline.
Split the plank out of the skewer with a #11 blade. You want it a little thicker than needed. Sand both sides of the plank smooth and end up with the desired thickness.
Sand an airfoil cross section to the plank. (See Harry Woodman's method in his scale models in plastic card book.)
Make more planks than just enough. You may only get half  the length of the plank usable if the skewer does not split evenly. Don't worry about it, just make enough to compensate and for broken or lost attempts. The skewers come a whole bunch to a pack, so only settle for the best examples.
Cut to length, use some kind of benchmark or jig to ensure they are all exactly the same length and trim ends as per the needs of your model.
Finally drill the ends and insert your favorite pin material. Bamboo grain is like tubes, so it drills real easy. Careful not to poke holes in your fingers.
I finished them with a watercolor pencil and then multiple coats of Pledge, tinted or clear as dictated by the subject. You can also paint them as you would plastic or resin ones,
Bamboo is incredibly strong, being slightly flexible adds to that strength. It is easy to work and looks good, you are going to like it.
sp
« Reply #161 on: May 07, 2020, 03:20:15 PM »
I must try this bamboo strut idea!  Thank you for sharing!
Offline RLWP
  • Bodger
« Reply #162 on: May 07, 2020, 05:34:31 PM »
Are the Hobbycraft struts that bad? They look quite finely moulded compared to some
« Reply #163 on: May 07, 2020, 09:14:22 PM »
Good Luck on your carving. My experimental strut only took about 15 minutes. The real ones will perhaps take longer  ::)
The kit struts are indeed finely molded. It the shape of the H struts that is troubling. The large indentation on the trailing edge of both front and rear is what bothers me. If the struts have an indentation it is not as prominent as Hobby Craft have Molded it. We will see how things go. I may end up using Alternate Plan B   8)
Offline RLWP
  • Bodger
« Reply #164 on: May 07, 2020, 09:49:37 PM »
Don't the struts neck down to the central fixing? My understanding is the vertical struts are in two parts
