Author Topic: RAF FE8, Scaleplanes 1:72  (Read 70627 times)
Offline smperry
Re: RAF FE8, Scaleplanes 1:72
« Reply #195 on: September 25, 2020, 05:49:41 AM »
I sure agree about the one piece, upper/lower control horns. Sooo much easier and the upper and lower horns align so well when you are done ;-)
sp
« Reply #196 on: September 26, 2020, 10:38:44 PM »
Sure hope you give those spiders a few extra beers ! ;)
 Fantastic job on the rigging and like the others I agree on the PE control horns , one piece is much better .
« Reply #197 on: October 11, 2020, 10:26:21 PM »
Another small update as I have to keep forcing myself back onto this one. I finally got the tail control lines all fitted.
and then got them trimmed up I only knocked one off while trimming, I was pretty pleased with that, and it went back on again without any problems as at least it had the forethought to come loose before I'd trimmed the end off the wire!
However, I did manage to cut one of the upper tail bracing wires while trimming, so more repair work. At least this one is simple to get to!
Next up was that flying wire I tried to reattach the loose end but it wasn't going to work so I trimmed it off and cut a length of 0.066mm nickel-chrome wire to replace it. It's almost exactly the same diameter as the fishing line so the only difference is the slight sheen to it, plus the fact that I can't tension it. It's not perfect but it will do!
While I had the wire out, I also added the cross bracing under the rear of the nacelle, and then attached the engine air intake and elevator control horns.
I now need to sit and make 8 tiny pulleys for the aileron control lines. Needless to say, I'm not going to do that now.
Beer time.
Stay safe all, and thanks for looking in!
« Reply #198 on: October 11, 2020, 11:17:56 PM »
One line at a time , your getting there Ian  :)
Offline Old Man
« Reply #199 on: October 14, 2020, 11:44:00 AM »
Good to see this plugging along, Sir.
« Reply #200 on: October 22, 2020, 11:21:09 PM »
Looking Incredible! I can't wait to see those Tiny Pulleys!
« Reply #201 on: November 07, 2020, 09:43:27 PM »
Thanks for the feedback folks, Rick, pulleys ahoy!
I have not been idle. Despite the lack of updates there has been progress, it's just been very slow. Here then is a summary of that progress.
When we last visited, I was getting psyched up to make lots of tiny pulleys. They are 1mm discs punched out of 0.25mm plastic rod, drilled, and mounted on 0.4mm aluminium rod.
I needed 8 so I made 8
Silly me, I should know better by now. 4 fitted on the underside and 1 left! The other 3 are watching me from somewhere not far away and sniggering to each other.
I also added 4 control horns while I was at it so I wouldn't have to wait for them to dry when I came to fit the wires. Of course that train of thought is only relevant if I don't didn't knock some off later anyway!
Which left me with this x2
Then it was time to add more wire! I had decided on a plan of action previously. There are double linkages on the ailerons with the lines joined just inboard of the inboard pulley, so I had decided to add the first line all the way to the outer attachment, then tie another line on for the inner attachment. The biggest problem was simply getting the line to sit on the edge of the .25mm discs so I could glue it in place. Eventually the outer lines were done.
Then when those were good and dry I tied on the inner ones and added a spot of CA to the knot to keep it from sliding.
Getting the lines attached to the control horns has always been a pig of a job. For some reason this time around I suddenly had an idea. I snipped off a short piece of plastic rod of the same size as the horns and cut a slot in one side with a micro saw. I then simply slipped this in under the wire, just behind the control horn, with the wire in the slot, then slid it across until the wire was resting against the side of the horn at exactly the right height. A drop of CA was added while I held the wire taut - easy to do as it was resting on the little plastic block, et voila!
To avoid pulling it off when tensioning the rear end, I used a piece of .25 x 1.5mm strip for the same purpose. Slipped under the wire just behind the horn it meant I wasn't pulling down on the CA joint while tensioning it.
It worked! The underside rigging is finished with the exception of the landing gear and elevator control horns (both of which, needless to say, have been knocked off!)
The landing gear has also been added.
It needs a little tweaking to straighten it up, and while I was attempting that, I loosened the left strut between the booms again.
I have managed to get it and the associated rigging back in place and am now leaving it well alone. I may remove the landing gear again to tweak the angle slightly but that will wait.
To sum up, I am now on the home straight. I need to fix the undercarriage, do the aileron rigging on the top side, including adding the pulleys and control horns, then finish and add the engine. Then it's a quick touch up around the cockpit and add the Lewis gun, and she's finished!
Stay safe, and thanks for looking in!
« Reply #202 on: November 07, 2020, 11:45:38 PM »
You aren't alone in the pulley adventure . When I made my and it came time to add the control lines I faced the same as you did and even managed to nock off a pulley or two .
She is looking fantastic and these smaller details really add to it . Your in the base and there load ....looking forward to the home run !
« Reply #203 on: November 10, 2020, 04:43:42 AM »
Inventive techniques and excellent results. I admire what you are doing, especially in 1/72nd!
« Reply #204 on: November 22, 2020, 10:48:15 PM »
Thanks Terri and Rick, much appreciated!
A small update today.
My silver marker has dried up so I've ordered another one. No point trying to finish the rigging until that gets here as I can't see it! So progress over the last couple of days has been in two directions:
Firstly the landing gear was removed, straightened, and refitted. She looks much better with both wing tips at the same level!
The second area of work was to finish off the ridiculously small and detailed engine I added the rocker arms and then the  push rods from steel wire. The prop got CAd onto it and it now awaits finishing of the rest as I will fit it once all the rigging as done and wheels have been fitted. The main reason is that I can hold it by picking it up with my thumb and index finger holding the nacelle. I won't be able to do that with the engine in place which only leaves the wing tips as areas to hold without breaking anything. Did I mention she's a tad fragile and very busy with rigging?
Anyway,
Here's the engine.
Thanks for looking in. Hopefully the next update will have the rigging completed
Stay safe!
« Reply #205 on: November 23, 2020, 11:50:37 PM »
Excellent work on the engine and prop  :)
« Reply #206 on: November 24, 2020, 12:22:23 AM »
The prop and engine are Fantastic! You are continuing to Impress!
« Reply #207 on: November 28, 2020, 09:58:05 PM »
Hi all, back again for another brief update, but first, thanks to Terri and Rick for the feedback - it's most definitely appreciated!
I did have a little OH **** moment earlier in the week when I tipped the turntable onto which I had taped the model, only to remember as it slid off onto the bench that I had removed the tape holding it in place! A quick check revealed that the left upper boom had popped loose at the tail end. Fortunately it was quickly and easily CAd back into place and all the rigging remains taut.
Phew!
An unexpected day off due to a schedule change has left me a little extra time to spend on this, although I'm still waiting for my new markers for the rigging. Having said that, at least I can get everything ready so when they arrive I can get straight on it.
Today's jobs then:
1) Finish the rigging on the underside - namely the elevator control horns and undercarriage.
Done!
2) Finish painting the cockpit edge (there was a metal bead around it, presumably to remove what could otherwise be a rather sharp razor like edge to the nacelle!) and add the pilot's head rest.
Done!
3) Add the pulleys and control horns on the upper wing for the aileron rigging.
Done! These pulleys are flush on the surface and not proud like those on the underside, which made them far easier to fit.
Jobs remaining now:
Aileron rigging on the upper wing
Repair a tail rigging line which I accidently cut when fitting the elevator lines.
Paint touch up on the control horns and one or two other areas
Fit the wheels
Fit the engine
Fit the Lewis gun - I also need to make a spent cartridge bag and do some work on the mounting.
Definitely on the home straight now!
Thanks for looking in, stay safe!
« Reply #208 on: November 29, 2020, 01:00:32 AM »
Stunning work Ian! The details are incredible. It amazes Me that there is no injection kit of this aircraft in any of the normal scales . It really is a cool looking bird!
« Reply #209 on: November 29, 2020, 07:16:23 AM »
I'm really impressed with this so far Ian , super work so far  :)
