Author Topic: 1/72 scale Fokker DR.1  (Read 3202 times)
Offline Rip Van Winkle
« on: February 23, 2020, 12:55:47 PM »
Just finished these two.  The newer Revell and an older Eduard kit.
Re: 1/72 scale Fokker DR.1
« Reply #1 on: February 23, 2020, 01:04:51 PM »
First the Revell kit.  This is either 193/17 or 197/17 depending on your resource. There is a lot of controversy about the color scheme and markings on this aircraft.
« Reply #2 on: February 23, 2020, 01:19:30 PM »
Colors used were Vallejo Model Color Prussian blue for the fuselage, Tamiya X-5 for the green nose,  Streaked camouflage was xtra color X-24 WW1 German topside green on top of Mister Kit GC 10 german clear doped linen.  Underside was Tamiya XF23. Seatbelts from Eduard, White fields painted except fuselage  which was all decal.
« Last Edit: February 23, 2020, 01:55:31 PM by Rip Van Winkle »
« Reply #3 on: February 23, 2020, 01:26:19 PM »
The only trouble with this kit was that the machine guns need some adjustment to fit.  Revell did a nice job reinventing this model. I still have some of the old ones. Rigging was with .15mm (.0005 in.) Nitinol black wire.
« Reply #4 on: February 23, 2020, 01:38:20 PM »
The second kit was an older Eduard kit I purchased from Ebay.  Model depicts Von Tutschek's Fokker Dr.1.  Same camouflage as the Revell kit.  Had to add some detail to the engine and cockpit. Seatbelts were from Eduard.
« Reply #5 on: February 23, 2020, 01:52:07 PM »
Overall I thought the Revell kit was a bit better. I have not built the Eduard dual combo yet so maybe there is a difference.  The streaked camouflage was a little to green for me. Next time I will use the same clear doped linen ( Mister Kit) but may try a enamel clear coat over that before streaking with an acrylic. I  do not have a lot of enamel paints  as they are so messy to use. I had some problem thinning the green paint and so the streaking is not quite what I wanted.  Next is a couple of Roden Pfalz D.III/IIIa. Pray for me!
« Reply #6 on: February 23, 2020, 11:49:57 PM »
Nice job ob both little Fokkers . I really like the blue one , never seen that scheme before . Looks very sharp !
« Reply #7 on: February 24, 2020, 04:12:05 AM »
Nicely done Triplanes. Like Terri I like the blue scheme! Thanks for sharing!
Offline AndRoby67
« Reply #8 on: February 25, 2020, 02:59:24 AM »
Hi Rip!
I have same kits to build and your suggestions about building are treaures.
I like your results, the less convincing part is the streaking camo, as you anticipate.
Sincerely, I bought the Aviattic decals set for this, because I'm sure I will be a disaster with brushes!
Many compliments!
Roberto
« Reply #9 on: February 25, 2020, 04:22:20 AM »
Thank you for the nice comments. I have the Aviattic Fokker Streaked decal sheet but still want to improve my streaked camouflage method.
« Reply #10 on: February 25, 2020, 04:26:25 PM »
Quote
Dito both of the bove comments !!!
« Reply #11 on: February 26, 2020, 03:42:09 AM »
Nicely done! Some really good modelling! Regards, Marc.
« Reply #12 on: February 27, 2020, 01:27:53 AM »
Thank you for the nice comments. I have quite a few of these in my stash so there will be more builds in the future.
« Reply #13 on: February 27, 2020, 03:12:43 AM »
A lovely pair of Fokkers indeed. I remember building the Revell kit many years ago (and still have the model), but you have certainly taken an old kit and made it inot a true gem of a model. The Eduard kit I am not familiar with - but again you have turned out a first class model.
