Author Topic: Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 10.10.2020 Rigging  (Read 30533 times)
Re: Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 19.9.2020 Suspension
« Reply #90 on: September 29, 2020, 05:26:56 PM »
Frank, the titel grabbed my attention.  Phenomenal work!
« Reply #91 on: September 30, 2020, 06:01:49 AM »
Been away for some days so I have had a lot of catching up to do! So I also cannot report progress, but I like to say:
Thank you Andreas (good to see you here again), Terri, Kevin, Marc, Ken, Rick, Stephen and Gaz!
It looks like you're making the turn from base to final on this build.
Oh, will try to find some time (and a bit of mood) the next days to continue on this one, but not sure about when it will be finished.
Welcome to the show Gaz!
But only the title? I had hoped that the user name itself stands for interesting projects that are always worth a click ;) 8)
See you, then!
Offline jeroen_R90S
« Reply #92 on: October 01, 2020, 06:12:21 AM »
Yes, they always are, Frank! Although I usually don't have anything meaningful to comment!  ;D
« Reply #93 on: October 11, 2020, 05:32:24 AM »
Rigging
My mood is not back completely. Made some silly mistakes, which need time to repair and need in general lot of time for easy things ... But I continued!
At first I was out of brass sleeves and had to cut new ones to be able to start the rigging.
I noticed some conflict between the wires and my bigger wheels, so I sanded down the tires a lot and have to repaint the tires.
On the pictures of the real bird I found two maintenance panels, so I decided to add them. Made from brass and I soldered a fake hinge to the lower end.
Tinned and painted. On the Cent there are some fasteners squeezed from 0,3mm brass.
Opened the wood behind and in place. Should have done this in earlier state, would be much easier.
Added control wire outlets and stripes of aluminium foil to the tail, to close the cutout.
The rigging is finished, as far as I'm aware of wires.
Also the control wires. Very hard to get them straight with this fishing line.
Tried to modify the kit levers. The position according to the manual does not make sense, but they are to big and cannot be mount as it should be.
I lost already glued wire outlets on the side, so I had to remove them on lower surface to replace missing ones and use now another type below.
On the control horns I no idea how to mount the turnbuckle to the huge control horns. At the end I used flat PE turnbuckles form a Parts set. Drilled a hole in the middle, bent them and mount with a micro rivet.
Some detail painting is needed and the front window is also missing, but then this bird is finished.
I think I will not add a weathering to this flat/matt paint and let it as clean object on display.
Re: Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 10.10.2020 Rigging
« Reply #94 on: October 11, 2020, 07:00:17 AM »
Now that looks really sharp Frank , looking forward on the final pic's . Excellent choice on not adding weathering , it would take way that air racer feel to it .
« Reply #95 on: October 11, 2020, 07:46:17 AM »
Rigging and weathering look Awesome! A beautiful little bird!!
« Reply #96 on: October 11, 2020, 05:20:18 PM »
Absolutely cool, Frank! 8)
« Reply #97 on: October 11, 2020, 09:09:47 PM »
Turned out beautiful, really appreciate every bit of this building. Thank you for sharing.
« Reply #98 on: October 12, 2020, 12:52:14 AM »
Looks like the rigging was more complicated than expected.  I may borrow your method of using the PE turnbuckles as attachment points, as the Avro has connections like this.
Still, a very unique model. I salute you, sir!
« Reply #99 on: October 12, 2020, 02:28:06 AM »
Thank you Terri, Rick, Andreas, Giuseppe and Ken!
At first I wanted to use my copper wire method like done on the Crocodile:
https://forum.ww1aircraftmodels.com/index.php?topic=9378.msg184945#msg184945
But here I need to connect a turnbuckle. And it was not possible to get a 0.3mm copper wire trough a Type C turnbuckle so I was forced to another solution.
« Reply #100 on: October 12, 2020, 02:54:21 AM »
More first class modelling a super fine details Frank. Your patience has been tested but it has survived the test and there is another winner almost completed here.
« Reply #101 on: October 12, 2020, 05:28:32 AM »
Not almost Stephen, it is completed now 8)
Painted some details like brass turnbuckles, added decals on sir screw and glued the framed windscreen in place.
Here are the final pictures:
https://forum.ww1aircraftmodels.com/index.php?topic=11586
Thanks for watching and all the comments during this journey!
« Reply #102 on: October 12, 2020, 07:08:01 AM »
I thoroughly enjoyed going over your build log.  The end result looks nothing like the beginning.  Outstanding modeling from Step 1 to the finish.  A neat little model and definitely a fast looking airplane.  Too bad all that nice engine detail can't be seen.  The engine is a real gem.
Re: Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 12.9.2020 Cockpit
« Reply #103 on: December 11, 2020, 12:12:56 AM »
At first: Thank you Mark for your kind words! Sorry, I haven't answered your nice post yet.
I'll bring up this thread again, since there was still a question about what the flag on the tail means:
A colleague found a picture: This seems to be the flag of the Gordon Bennet Cup:
Full site here and picture source: https://www.artcurial.com/en/lot-aeroplanes-deperdussin-deux-catalogues-et-deux-depliants-2963-5
Cool, again something clarified!
« Last Edit: December 11, 2020, 12:17:21 AM by Bughunter »
Offline TimDEFR
« Reply #104 on: December 29, 2020, 09:48:38 PM »
Superb job on the rigging! Staying tuned to your build.
Best,
Tim
