Author Topic: Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 10.10.2020 Rigging  (Read 30086 times)
Re: Deperdussin Monocoque 1912, AJP Maquettes, 1/48
« Reply #15 on: February 27, 2020, 05:00:31 AM »
Wow Frank, that engine is a masterpiece all onto itself, not to mention the rest.
« Reply #16 on: February 27, 2020, 07:40:47 AM »
When will Small Stuff start making big stuff?
Fine looking engine, Frank.
« Reply #17 on: February 27, 2020, 08:13:34 AM »
As always stunning engine Frank!
« Reply #18 on: February 28, 2020, 11:38:25 AM »
Yup , that is a lot of parts for one engine , but your results speak for themself , well done Frank  :)
Offline Brad Cancian
    • Brad's Models
« Reply #19 on: February 28, 2020, 06:05:15 PM »
Beautiful work. That engine is a real gem.
BC
Online PrzemoL
« Reply #20 on: March 03, 2020, 11:33:31 PM »
Great modelling.
And the engine is truly a gem as one can expect from Small Stuff. They do almost the same magic in 72nd scale!
« Reply #21 on: March 04, 2020, 01:11:26 AM »
   Beautiful job on the engine Frank, that is a real jewel! Yet another beautifully crafted unique design for your collection, you are indeed a "modelling machine"! :) 8) :) 8)
« Reply #22 on: March 05, 2020, 08:07:09 AM »
That Gnome Lambda-Lambda is a real mini-masterpiece. Small Stuff engines really are first class and you have demonstrated why. I am not sure what you can do about the fuselage though, but I am certain that you will come up with an original and innovative solution.
« Reply #23 on: March 05, 2020, 07:37:33 PM »
Wow,
What a super interesting kit Frank! I wonder if something like Danish Oil would have worked on the fuse?
Engine is fantastic!
« Reply #24 on: March 05, 2020, 08:41:45 PM »
Beautiful engine. Small stuff is producing really great stuff, processed into a stunning reproduction.
Offline Jorgo
« Reply #25 on: March 08, 2020, 05:13:19 AM »
Excellent engine, Frank! I admire your patience and accuracy
Jörg
« Reply #26 on: August 29, 2020, 02:55:07 AM »
... and again the 120 day warning ::)
Thank you all for your great feedback!
This project stopped somehow with my last exhibition before Corona, and after that other projects took over the bench, e.g. the Benz Motorwagen. After the finish of some other models I will give this project another try.
Regarding the wooden fuselage I changed my plans and will do this racer as actual looking in the museum.
Offline fredjocko
« Reply #27 on: August 29, 2020, 04:01:05 AM »
Talk about making a silk purse out of a sow’s ear. Amazing work!!!
« Reply #28 on: August 29, 2020, 05:42:10 AM »
Frank you seem to be a modelling machine at the moment. This is number three in about as many weeks....! Good to see that you are picking it up again though.
Stephen
Deperdussin Monocoque 1912, AJP Maquettes, 1/48, Upd 29.8.2020 Wings
« Reply #29 on: August 29, 2020, 08:51:42 PM »
Thank you!
Wings
New game - next level!
For the wings, the kit only foresees the covering of the etched wings with paper and a subsequent bending - no, not for me.
I have already made this experience with my Demoiselle, this has several problems:
- The wings are thin, but not that thin!
- You should glue the paper as a "pocket". If the upper and lower side touch each other, which is easily possible, because the paper is curled wet and has only an etch part thickness as distance, you never get it apart again and it looks like sh.. >:(
- in the original the bottom side was rather flat and not curved.
My solution idea: thin wooden strips.
On the circular saw, it only worked with such thin slats after I had inserted a new saw blade.
I glued strips of different widths on both sides of the wings with CA, here the upper side, on the right already a little bit sanded.
And the lower surface:
Finally sanded. To prevent the light yellow brass from shining through, I painted the free areas with wood brown.
View in profile:
As a "bag" it didn't work at all, in the third try I glued the bottom side first using diluted wood glue alone.
And then the top side.
The look with translucent light is fantastic!
And an impression with the wings attached to the fuselage. Already very smooth, although not yet really dry.
That was a lot of work, but it was worth it.
