Author Topic: Paint stripping  (Read 3040 times)
Paint stripping
« on: December 27, 2019, 01:01:28 AM »
Hell all,
I know it’s been asked before, just can’t remember how!
I need to strip a paint job, lacquer acrylic undercoat and Humbrol enamel top coat?
Many thanks
Re: Paint stripping
« Reply #1 on: December 28, 2019, 12:38:49 AM »
I still use brake fluid and a tooth brush and cloth. I have heard others use green degreaser. In addition I am sure there are some specialty strippers out there, I just don't use them. IHTH
Re: Paint stripping
« Reply #2 on: December 28, 2019, 07:51:47 AM »
Thanks Rick,
I’ll have to experiment..
Offline Suffolk Lad
Re: Paint stripping
« Reply #3 on: December 29, 2019, 04:14:14 AM »
99% Iso Propyl Alchohol will take acrylic down to the plastic Guy without damaging the surfaces - not sure about the enamel though so maybe test on an undersurface first?
I have used with complete success the Mr Muscle oven cleaner 'treatment' before - put parts in large sealable poly bag, spray in a copious amount of oven cleaner, seal bag and leave overnight. Wash parts under a tap following day.  Resurected previously painted parts for a 1/48 Helldiver quite recently - all back to like new overnight. The parts had been painted a long time before I got it and were probably painted with Humbrol but can't be ceratin - again you really need to do a test.
Hope that helps a little more
Tug
Re: Paint stripping
« Reply #4 on: December 31, 2019, 06:21:55 AM »
Thanks Tug,
Sounds messy!
Re: Paint stripping
« Reply #5 on: December 31, 2019, 10:55:14 PM »
Here is a photo from My DR1 build. Had to strip one side. Managed to strip what I needed and save the rest. Stripped as stated above. It had a base of acrylic beige and was covered with Drooling Bulldog Lacquer red.
Offline Suffolk Lad
Re: Paint stripping
« Reply #6 on: January 03, 2020, 06:40:03 AM »
Thanks Tug,
Sounds messy!
No it's not that bad actually Guy, the Mr Muscle settles to a liquid over night - just a matter of bringing the parts out and washing them under a tap.
Using IPA is though but it's ideal for small parts or areas that have gone wrong. It's okay to use on canopies too.
Tug
Re: Paint stripping
« Reply #7 on: January 03, 2020, 06:48:11 PM »
Thank you both,
I have now managed to avoid the stripping by a bit of sanding and a re paint. But this is a skill I need to have in my locker!
The problem with the oven cleaner is I wanted to strip the airframe but leave the cockpit intact...
Offline Suffolk Lad
Re: Paint stripping
« Reply #8 on: January 08, 2020, 06:03:08 PM »
Hi Guy - been out of things for a day or two  :(
Careful application of IPA it is then - but as you say it is a bit messy! As always best to try it on something that doesn't matter too much first to get the hang of it - good luck with it
Tug
Re: Paint stripping
« Reply #9 on: January 08, 2020, 06:45:21 PM »
Thanks Tug,
Will do..
