Author Topic: WNW Hannover Cl.II (Early)  (Read 11948 times)
Re: WNW Hannover Cl.II (Early)
« Reply #15 on: November 30, 2019, 04:24:40 PM »
Excellent work so far.
Offline gcn
« Reply #16 on: November 30, 2019, 05:57:01 PM »
I did the exact same method when I built mine.
It is time consuming, but what I would say is you don’t need to be too fussy in tidying up the lozenge as once you overpaint it pretty much disappears and you are just left with a faint outline of what went before.
« Reply #17 on: November 30, 2019, 11:53:54 PM »
Outstanding work on the masking and painting of the lozenge! Your interior is stunning.
Offline uncarina
« Reply #18 on: December 01, 2019, 12:19:17 AM »
Thanks Giuseppe! I hope to keep my momentum.
Cheers,  Tom
Offline uncarina
« Reply #19 on: December 01, 2019, 12:26:14 AM »
That’s good to know! Yes, I am counting on that for the fuselage sides and top: just enough to know it’s there without having to repeat what I did on the bottom. In fact, I have cut out a series of lozenge shaped holes in masking tape and am now placing and spraying each individually. As I mentioned, I am painting only the colors that are lighter and darker than the Prussian blue overspray as a shortcut.
Cheers,  Tom
Offline uncarina
« Reply #20 on: December 01, 2019, 12:27:56 AM »
Thank you! You are very kind. I am continually inspired by the work you and the other modellers contribute on this forum.
Cheers,  Tom
Offline Berman
« Reply #21 on: December 01, 2019, 05:11:34 AM »
There are acrylic drying retarders available. Not sure if they will work with acrylic oils. A knowledgeable art supply store can tell you the correct product to use.
Offline uncarina
« Reply #22 on: December 01, 2019, 07:42:54 AM »
That might be worth a try. My workaround has been to work fast with a broad brush!
Cheers,  Tom
Offline uncarina
« Reply #23 on: November 12, 2023, 09:40:48 AM »
After a four year hiatus I've decided to pick this one up again. Since my last post I've added the painted lozenge for the fuselage sides and top, but not as meticulously as the lower surface since it was lightly painted over in the dark color, along with the "01" on each side. I've also ordered the Aviattic five color alternative lower lozenge pattern for upper surfaces, and I will start working on the wings as I finish up my current build.
Cheers,  Tom
« Reply #24 on: November 12, 2023, 08:02:02 PM »
Hi Tom,
The 'DecoArt' oil paints are good.
You could try, if you've done so already, the 'Windsor & Newton' Alkyd oil paints.
As usual brush on, then thin out with white spirits or odorless thinners and leave to dry.
Not as fast drying as the 'DecoArts' oils, but much quicker than standard oil paints,
Offline uncarina
« Reply #25 on: November 13, 2023, 12:48:53 AM »
Thanks Mike, I haven’t worked with them yet and will try them out.
Cheers,  Tom
« Reply #26 on: November 13, 2023, 04:44:03 PM »
Lovely paint work!
Offline uncarina
« Reply #27 on: November 14, 2023, 12:12:14 AM »
Thank you! I’m really looking forward to seeing this build through.
Cheers,  Tom
Online Tim Mixon
« Reply #28 on: November 14, 2023, 09:31:09 AM »
Beautiful work Tom. Glad to see you have picked this up again. Looking forward to seeing more.
Offline uncarina
« Reply #29 on: November 14, 2023, 12:15:55 PM »
Thank you Tim! I appreciate your encouragement. As I finish up my current build I will be starting on the wings and tailplanes next.
Cheers,  Tom
