Author Topic: 1/16 Hasegawa Sopwith Camel  (Read 9389 times)
Offline Composite Guru
« on: October 24, 2019, 06:52:00 PM »
Hi I’m new here and thought I would share a few pics of my current build.
I’ve always fancied building one of the 1/8 scale wooden versions but they are really expensive and quite huge so decided on taking a punt on the smaller plastic version.
So far I’ve enjoyed everything about the kit and really looking forward to finishing it.
I’ve learnt a lot about how to create wood effect from using oil paints over a base colour. I think it looks like wood in that scale.
The kit comes with all the rigging but unfortunately it isn’t that accurate as most relies on just tying the cord through loops in the structure.
I’ve decided to hand make all the turnbuckles as you can’t  buy 1/16 turnbuckles off the shelf. It’s been fun making them though.
Here are a few pics of the build so far.
https://thumbsnap.com/s/NYMxi6eT.jpg[/img]|https://thumbsnap.com/NYMxi6eT]|https://thumbsnap.com/NYMxi6eT
https://thumbsnap.com/s/xreFouTz.jpg[/img]|https://thumbsnap.com/xreFouTz]|https://thumbsnap.com/xreFouTz
https://thumbsnap.com/s/W5q0trcd.jpg[/img]|https://thumbsnap.com/W5q0trcd]|https://thumbsnap.com/W5q0trcd
https://thumbsnap.com/s/jzPb56YW.jpg[/img]|https://thumbsnap.com/jzPb56YW]|https://thumbsnap.com/jzPb56YW
https://thumbsnap.com/s/JMxAeDxG.jpg[/img]|https://thumbsnap.com/JMxAeDxG]|https://thumbsnap.com/JMxAeDxG
https://thumbsnap.com/s/6RaRoVDq.jpg[/img]|https://thumbsnap.com/6RaRoVDq]|https://thumbsnap.com/6RaRoVDq
https://thumbsnap.com/s/vIrczCW1.jpg[/img]|https://thumbsnap.com/vIrczCW1]|https://thumbsnap.com/vIrczCW1
https://thumbsnap.com/s/2IIqHznm.jpg[/img]|https://thumbsnap.com/2IIqHznm]|https://thumbsnap.com/2IIqHznm
https://thumbsnap.com/s/TWCnUYau.jpg[/img]|https://thumbsnap.com/TWCnUYau]|https://thumbsnap.com/TWCnUYau
https://thumbsnap.com/s/KrMa0aQA.jpg[/img]|https://thumbsnap.com/KrMa0aQA]|https://thumbsnap.com/KrMa0aQA
Finally finished rigging the Wings. Just got the Fuselage to do now.
Rigging has really been quite enjoyable rather than a chore. Looks pretty realistic I think. The original kit asks to thread one piece of cotton throughout the whole wing. This is not very accurate hence doing what I’ve done.
Not too long until I can start assembling the whole thing.
https://thumbsnap.com/s/AbDHRwX5.jpg[/img]|https://thumbsnap.com/AbDHRwX5]|https://thumbsnap.com/AbDHRwX5
https://thumbsnap.com/s/lQp6XRUw.jpg[/img]|https://thumbsnap.com/lQp6XRUw]|https://thumbsnap.com/lQp6XRUw
https://thumbsnap.com/s/kodvOOaL.jpg[/img]|https://thumbsnap.com/kodvOOaL]|https://thumbsnap.com/kodvOOaL
After rigging the tail area I decided to fit the cockpit floor with all the control cables installed.
Treading them all through the Fuselage was fun making sure they didn’t twist around each other.
Just need to temporarily fix the control stick in the centre some how so that I can tension the control cables.
Also installed the magazines and engine oil tank too and then finished off the dashboard.
Next thing to do is add all the fuel pipes from all the various system parts to make it look a bit more realistic.
https://thumbsnap.com/s/u4OThZVZ.jpg[/img]|https://thumbsnap.com/u4OThZVZ]|https://thumbsnap.com/u4OThZVZ
https://thumbsnap.com/s/H4afSlgh.jpg[/img]|https://thumbsnap.com/H4afSlgh]|https://thumbsnap.com/H4afSlgh
https://thumbsnap.com/s/cn5ioMuI.jpg[/img]|https://thumbsnap.com/cn5ioMuI]|https://thumbsnap.com/cn5ioMuI
https://thumbsnap.com/s/LRTtc5YL.jpg[/img]|https://thumbsnap.com/LRTtc5YL]|https://thumbsnap.com/LRTtc5YL
Ok so I have the Rudder and Elevator all rigged and tensioned. Made up some jigs out of lolly sticks to hold the column and rudder bar central.
Cockpit coming together slowly. Adding as much copper wire as I can to join up all the fuel system parts.
https://thumbsnap.com/s/bkvs7cx1.jpg[/img]|https://thumbsnap.com/bkvs7cx1]|https://thumbsnap.com/bkvs7cx1
https://thumbsnap.com/s/gt1MsPt1.jpg[/img]|https://thumbsnap.com/gt1MsPt1]|https://thumbsnap.com/gt1MsPt1
https://thumbsnap.com/s/WJ36CIyK.jpg[/img]|https://thumbsnap.com/WJ36CIyK]|https://thumbsnap.com/WJ36CIyK
https://thumbsnap.com/s/Y3kp0drt.jpg[/img]|https://thumbsnap.com/Y3kp0drt]|https://thumbsnap.com/Y3kp0drt
https://thumbsnap.com/s/0zQWndyj.jpg[/img]|https://thumbsnap.com/0zQWndyj]|https://thumbsnap.com/0zQWndyj
Finally got the wings on. Getting the thing sat flat was the hardest bit.
Just the engine and a few other panels to go on and finish ringing it.
https://thumbsnap.com/s/TOpheKT5.jpg[/img]|https://thumbsnap.com/TOpheKT5]|https://thumbsnap.com/TOpheKT5
https://thumbsnap.com/s/VLpxMNzx.jpg[/img]|https://thumbsnap.com/VLpxMNzx]|https://thumbsnap.com/VLpxMNzx
https://thumbsnap.com/s/317FCmTO.jpg[/img]|https://thumbsnap.com/317FCmTO]|https://thumbsnap.com/317FCmTO
Re: 1/16 Hasegawa Sopwith Camel
« Reply #1 on: October 24, 2019, 09:35:38 PM »
WOW ! You have made quite an entrance to the Forum  8) Your construction, painting and detailing is exceptional. The framework rigging is incredible... Very Well Done!
« Reply #2 on: October 24, 2019, 10:55:47 PM »
    You are taking this Kit to a whole new dimension, Rick has used the word "incredible" and I certainly second that! Lovely work. great detail added and very real looking in all respects. Wonderful Model!
Offline jeff shreve
« Reply #3 on: October 25, 2019, 02:15:57 AM »
Agree with the others on what a great job! I have this kit and would have just done a quick build of it - but can't now.  Did you strip and repaint the metal colored parts or leave them in the color they come in and weather them?
« Reply #4 on: October 25, 2019, 06:08:36 AM »
Impressive and tempting! Well done on the wood!
« Reply #5 on: October 25, 2019, 04:34:47 PM »
Thanks for the comments. I do try my best to make my models look realistic. It is worthwhile in the end.
As for comments about the metallic parts. I did strip them and repaint. The fuel tank did need doing as there was a join that needed filling. Plated parts never look right though so I would do this every time.
« Reply #6 on: October 25, 2019, 06:38:17 PM »
Totally agree with the comments above - outstanding work.
Welcome to the forum!  ;)
von B  :)
« Reply #8 on: October 29, 2019, 05:20:16 AM »
Very nice results.  That's going to be a looker!
Ken M.
« Reply #9 on: October 29, 2019, 03:42:15 PM »
Cool work, so many details to discover.
Bye,
« Reply #10 on: October 29, 2019, 07:13:47 PM »
Thanks for the comments. Its a great looking model. Defo centerpiece worthy.
Offline FokkerFodder
« Reply #11 on: October 29, 2019, 08:46:54 PM »
Hi - yes, you’re doing a great job on this kit. I’m in the final stages of finishing one as well.
Matt
« Reply #12 on: October 29, 2019, 09:27:31 PM »
Matt
Thanks. Do you have a build thread?
I would like to see your work on this. I'm a casual modeller so I suspect yours will be better than this effort.  ;D
« Reply #13 on: November 04, 2019, 11:34:28 PM »
I don't know how I missed this last update. All I can say is Superb!
« Reply #14 on: November 05, 2019, 12:51:35 AM »
She is a KEEPER!
Lovely Camel  :o
Looking forward to seeing the Prop. If it's anything like the Camel, it will be perfect - well done!
Von B
