Author Topic: Morane Saulnier Typ N 1/32 Special Hobby  (Read 7289 times)
Offline Nigrivender
  • Do wrong and it will be good
« on: September 25, 2019, 07:00:57 AM »
Hello,
This time Morane Saulnier N on 1/32 scale by Special Hobby came to the workshop. After inspecting the parts, I come to the conclusion that the model will turn out to be pleasant to assemble. Although I had a puzzle difficult to solve when choosing painting. After studying the materials I am "forced" to perform painting in RFC colors :D. At first, I was very eager to do it in painting the pilot Smirnov from Russia. It turned out, however, that he flew on Morane but on Type I. Type N is significantly different from I. The first  important thing is the armament, N had Hotchinss and Type I already Vikckers, the part before the pilot covering the Vickers rifle was also changed. Type N was powered by the 80 -HP Le Rchone 9C engine, and type I 110-Hp by Le Rchone. Hence another engine cover, different hubcap and propeller. Type I already had a synchronized cannon. The difference can be seen in the attached photos.
Typ N
Typ I
Returning to the model. I will try to make it in such a painting.
And I was going to do it
And what I was able to do. This will make a new truss. And here I have questions whether there was a plate behind the pilot's seat or an empty space with a truss, and whether there was a floor because here they suggest differently.
From SH
and mine
If something can't be repaired it means it's not broken
Offline Ryan
Re: Morane Saulnier Typ N 1/32 Special Hobby
« Reply #1 on: September 25, 2019, 07:21:11 AM »
I like this kit and have it in progress.
Not sure how accurate, but I built a floor in the pit.
https://forum.ww1aircraftmodels.com/index.php?topic=9834.msg179177#msg179177
Ryan
Upcoming: Not sure!
Offline Gene K
« Reply #2 on: September 25, 2019, 08:40:24 AM »
A wonderful lead in post - thanks!
Gene K
« Reply #3 on: September 25, 2019, 08:55:50 AM »
Great start on a neat subject, looking forward to your progress.
« Reply #4 on: September 26, 2019, 02:50:52 AM »
Nice start!
You showed interesting pictures! My Type-I project in 1/48 is on hold, because I do not now yet, how this russian I cockpit covering really looks like and how to create that from scratch.
Do you have a front picture of an I?
« Reply #5 on: September 26, 2019, 05:03:56 AM »
This kit can be made into a nice model.
The one I made is on my site (link below) in gallery1.
The kit does not supply the MS logo for the engine cowl - I printed mine, but I think you can the logo in 1:32 scale here:
http://www.tomsmodelworks.com/catalog/index.php?cPath=22_30
Offline Nigrivender
« Reply #6 on: September 26, 2019, 05:51:12 AM »
Hi,
BugHunter,
 Only these type I photos (maybe I will find something). I don't have cockpit photos.
Mike,
The page is unfortunately not loading. And I use the logo with Begemot decals, nr 3
Offline O_Pablo
« Reply #7 on: September 26, 2019, 06:21:37 PM »
Hi Nigrivender,
below are two drawings of the Morane-Saulnier cabin. The upper and lower profiles should be rather square, the struts between them round.
Two photographs (probably known to Bughunter). In my opinion, in Russian Morany, the cover was rather slightly rectangular at the top.
All photo found at the web.
Offline Nigrivender
« Reply #8 on: September 26, 2019, 07:53:42 PM »
Hi,
Thank you for the illustrations :). However, my work has progressed and I will not change. I will show you my progress soon.
PS I made the N version :D, not I. I do the Bughunter and he will use it very much. ;)
« Reply #9 on: September 26, 2019, 11:01:20 PM »
Excellent work on the framework! I am looking forward to following your build!
Offline Ryan
« Reply #10 on: September 27, 2019, 12:25:54 AM »
Something to watch out for is that the trailing edges of the wings are not level if you just plug them in the locating holes. (One wing trailing edge is higher than the other.)
Just a heads up.
Upcoming: Not sure!
Offline Nigrivender
« Reply #11 on: September 28, 2019, 07:10:57 AM »
Hi,
Slowly forward, there are a few small things left and I will close the hull.
« Reply #12 on: September 28, 2019, 07:21:28 AM »
The interior is looking excellent! Looking forward to your next update!
« Reply #13 on: September 29, 2019, 04:33:01 AM »
Good progress, I like the cockpit.
And thank you all for trying to answering my question!
« Reply #14 on: September 29, 2019, 09:07:51 PM »
Nice clean work  :)
