Author Topic: 1/72 Hansa Brandenburg W 13  (Read 14109 times)
Re: 1/72 Hansa Brandenburg W 13
« Reply #15 on: September 16, 2019, 07:34:09 AM »
Evening All,
Many thanks Rick, Dave, Ken, Terri, Frank, Ian and Roberto for the very encouraging comments which you have left.
Dave: I will continue to provide scratch build projects in God's Own Scale but I have to state that I do have a larger scale project on my list so there will be a hiatus at some time in the future!
This has been a week in which I have been learning some dark arts in the use of an electric drill, (ie a Dremmel) on laminated plastic. I decided not to try to mould the upper decking of the hull as this would have meant carving a mould from basswood and then trying to push mould a piece which would sit exactly on the curved upper hull sides. I could see clearly that much frustration and wasted plastic lay on that route so I opted instead to do what I had done on the H-B CC and make the upper decking from laminated plastic. I made one piece which would sit comfortably over the gap in the upper hull:
A centre line had been drawn on the top of the new hull piece to help me to sand the correct curvature in the nose area and to make sure that the piece was properly centered on the hull. However I did not measure the thickness of the top correctly, and despite adding what I thought was adequate extra card to correct the problem I found that I still did not have enough depth and to avoid unsightly joins on the finished upper decking I decided to scrap the piece and start again.
This time I got the thicknesses right so I went ahead and scribed with a pair of dividers where the gunner's cockpit would be and traced and scribed the outline of the pilot and navigator's cockpit. However when I tried to drill out the gunner's cockpit I found that the Dremmel was so fast, (even on the slowest revs), that it melted the plastic and tore a larger hole than what I wanted! Time to make a third decking piece!
Number three was more successful: I was able to get the correct thickness and to drill holes ready to remove the plastic from the cockpit openings without gouging out an excessively large hole. I did this by drilling one hole at a time and stopping the drill to allow the bit to cool between each drilling individual holes. I also cleaned off any plastic which had stuck to the bit and made sure that the holes were not to close to the scribed edge of the cockpits. Here are the two efforts with the failed second attempt on the left:
The holes were joined with a scalpel blade so that the centre pieces of plastic fell out and the the final shaping of the cockpit openings was completed with a round and half-round file. A long and somewhat laborious process but as I learned the hard way, one which cannot be rushed.
With the cockpit openings complete I added some basic cockpit details - seats, a control wheel, a panel between the pilot and navigator seats and a seat for the gunner. Very little of this will be visible on the completed model and I do not belong to the school of modelling which insists on adding details which will be forever hidden once the model is complete. I am happy to know that those details are missing and wish to spend more time on getting an accurate outline and detail which can be seen! I also filed the upper decking to the shape of the side profile prior to fixing it in place as this required some hard scraping which would have risked causing damage to the hull if I had glued it in place beforehand. In doing this I got a little carried away and took too much from the top of the rear deck and had to build this area up with filler - hence the large grey area in the image below. I also removed much of the excess plastic on the sides of the decking at this stage again to reduce the risk of damage to the hull sides.
The upper decking was glued to the hull and held in place overnight with the same state-of-the-art sophisticated equipment as was employed earlier to hold the hull bottom in place and described above. The centre line on the decking enabled me to get the accurate positioning for the cockpits relative to the rest of the hull. From the left (port) side the hull now looked like this:
Final shaping could now begin. First the sides of the upper decking were filed so that they were flush with the rest of hull sides and then the curved nose section in front of the pilot's cockpit was sanded to shape: I used a card template made from a cross-section diagram on the plans to achieve as close a match to the profile as I was able. The centre line and a cross line can be seen on theses images: the latter marked where the template was used to check the cross profile. You van also see the filler that I had to add to the hull sides below the decking to remove a small step caused by the thin plastic bending inwards when it should really have curved slightly outwards. I am hoping that none of this will show when the hull is painted and the wings are in place....
Having got the decking as I thought that I wanted it I checked the lower wigs against the sides of the upper decking - and found that in spite of the filler the shape was still not right....! So out with the file and remove the front end of the filler to the plastic below and glue into place a piece of 20 thou card. A file and glass paper were brought into action when the plastic was firm and the edges of the new piece of card concealed with yet more filler....
Now the wings fit without an unsightly gap. Still the hull is not complete however. I have made a fin from 60 thou card with two pieces of 20 thou card at the base. The fin of this machine was very wide at the base and tapered upwards so I had yet more filing, sanding and filling to do before it was finished:
Now I can add the gunwale along the sides of the nose and bomb rack strips to the front section of the upper hull, but more of that in a later post.
Thanks for looking.
« Reply #16 on: September 16, 2019, 09:32:40 PM »
Those Dremels can get you in a lot of trouble, and thank God for filler (putty).
I have a light dimmer switch wired into my single speed Dremel just to slow it down so it won't melt plastic.  I got this idea from Dremel themselves.  It will only work on single speed Dremel tools.
Its good to see progress on this - coming along nicely!
« Reply #17 on: September 16, 2019, 10:40:27 PM »
What can I say other than your Usual Spectacular scratch building!
« Reply #18 on: September 17, 2019, 12:17:36 AM »
Lovely work as usual Stephen. In cases like this miliput UA your friend!
« Reply #19 on: October 05, 2019, 08:42:20 AM »
Evening All,
Thanks Ken, Rick and Ian for the helpful comments. Unfortunately my Dremmel is a multi-speed so I cannot use any devices to slow it down: I will just have to take extra care when drilling thick plastic and keep cleaning the bit. It is still quicker than trying to drill by hand!
It has been a little while since the last post and I do not seem to have achieved a great deal in the interval - as usual life has got in the way. There are also times when in the course of scratch building a model a great deal of time seems to be required to achieve not very much, and then a great deal can be achieved in a short time. I am hoping that I might be moving from the former to the latter....
I have fixed the wings and horizontal tail surfaces to the hull - they are butt joined with liquid cement, (bog standard Humbrol liquid poly). Given enough time to dry properly, and supported while they dry this gives a good clean and firm joint. I then primed the fuselage with Revell acrylic ocker (88). Later I will apply oils to represent the wood of the hull:
The dark areas on the top of the mid-hull are filler but these will not show through the oil paints.
Next were the floats. Originally I thought that I would make them from card and started with sides from 30 thou card with bulkheads between. I had intended to bend some 20 thou card to make the top and bottom surfaces but because the front ends of the floats are slightly tapered this was going to cause gaps to appear and I could see disaster looming:
So I adopted instead the method which I had used on previous flying boats (Phoenix A and Hansa-Brandenburg CC) by making them from laminated card. The procedure is simple: glue together sheets of thick card with thick styrene cement from a tube and place under some books for at least 12 hours. Mark out the plan of the float:
Cut away excess plastic with a razor saw:
Shape the remaining plastic with a file and glasspaper and
there is a float with the second block of laminated card ready to be treated in the same way: and here is the pile of dust that is generated by the process:
(For those who do not know the above picture shows the corner of the old tray that I use as a "bench" on which I make my models. I have had it since I started modelling when I was 10-11 years old and it is still the main surface on which I work).
The hull and floats have now been painted with oils and are currently drying in my airing cupboard: I expect them to be there for 2-3 days depending on the temperature inside the cupboard. Because watching and waiting for paint to dry is a bit tedious I started on the engine: when I laminated the plastic for the floats I also made up a piece for an engine block. This was filed and sanded to shape and the cylinders added from 80 thou rod. The insides of the "cylinders" were drilled so that I can add the inlet manifolds from 20 thou rod, one of which has been inserted (but not cemented):
More to follow in due course.
Thanks for looking.
« Reply #20 on: October 05, 2019, 11:45:53 PM »
WOW! Another one of your Fantastic builds is moving along quite well! Your skills are amazing as I have said before!
« Reply #21 on: October 06, 2019, 03:30:33 AM »
What a update! That little seaplane looks nice and the engine is so cute with 12 cylinders!
You made a good progress here.
« Reply #22 on: October 06, 2019, 04:25:14 AM »
Super scratching, Stephen  :)
I'm still trying to work out why this thread has only just come to my attention  ::)
Keep up the great work.
Von B
« Reply #23 on: October 06, 2019, 04:28:54 AM »
Beautiful and speedy start of your scratchbuilt plane. Following with great expactations.
« Reply #24 on: October 07, 2019, 04:41:00 AM »
A significant update.  I think you have pushed through the 'slow' period and moved on to more interesting things!
You mentioned the waiting for the oil paint to dry.  The comment made me think of the food dehydrator I use to speed up paint drying.  I can post some pics if you are interested.
You have captured the overall shape quite nicely.
« Reply #25 on: October 07, 2019, 05:45:30 AM »
Always enjoy following your builds , just awesome !
Offline AndRoby67
« Reply #26 on: October 11, 2019, 11:57:29 PM »
Hi!
Fantastic work! I'm keep following you.
Many things to learn to!
Roberto
« Reply #27 on: October 14, 2019, 05:55:58 AM »
Evening All,
Thanks Rick, Frank, Von B, Giuseppe, Ken, Terri and Roberto for the positive and encouraging remarks - they are much appreciated.
Ken: I place my models in an airing cupboard to dry off the oils. It is a very small room with a hot water tank which has slatted shelves above the tank and is used to dry clothes. It is ideal for drying paint too, as it is constantly warm but not too hot. Naturally there are no clothes in there when I am drying the paint on a model!
Painting and decorating is almost complete now: there is more to do as I add pieces here and there but they will be done when the correct time arises - in the meantime the main components are finished. The hull was painted with oils - burnt siennsa with a small amount of raw sienna, and the whole dried for three days in a warm airing cupboard. Then two thin coats of Revell clear orange varnish completed that part. The wings were painted with many coats of Revell white with a small amount of Humbrol 103 linen. I mix the paints with water until they have the consistency of milk and draw the brush in alternate directions across the wing and along the wing with each coat. This ensures an even coating each time - the last coat is always in the direction of airflow - ie from front to back. The red/white wing, tail and rudder bands were matt Humbrol enamels (34 and 60). The transfers were printed for me by Arctic Decals: I could have printed the crosses but not the numerals so I gave an order for both and can say that I am very pleased indeed with both the quality of the transfers and the very prompt service. I will definitely be using them again:
So the model parts now look like this from the top:
and this from under:
From the sides:
The cross on the nose was hand painted as I could not think of a way of making a transfer(s) that would fit. The cross on the fuselage side was home printed.
I have also been working on the engine while paint has been drying and this is now nearly complete - I may add a couple of small items to the sides when it is fixed to the platform on the model as they are difficult to fit and there is a real risk that they will be knocked off:
That is all for now. More updates when I have the engine assembly on the fuselage.
Thanks for looking.
Offline Robin
« Reply #28 on: October 14, 2019, 06:08:04 AM »
Beautiful and fantastic how you do this. Mind blowing!
Robin  :)
« Reply #29 on: October 14, 2019, 07:35:03 AM »
Amazing work Stephen.
