Author Topic: TP's WNW 1/32nd Scale Biff  (Read 56065 times)
Offline Trackpad
Re: TP's WNW 1/32nd Scale Biff
« Reply #60 on: December 06, 2012, 05:22:50 AM »
...this becoming model builder porn...Im assuming you're beyond wanting to adopt.
Steve,
Not quite sure what your point, or question, is here. Please clarify. TIA.
Cheers!
« Reply #61 on: December 06, 2012, 05:29:58 AM »
PS: The Spit is a Canadian subject, and the Spitfire ale just sort of "turned up...!"  ;D
Hello Gary:
No blathering; and it does help.  I like the effect you have with the weathering, not overly done but weathred a bit, and the work with the lettering and insignia is truly outstanding.  Now, to find some Spitfire here in the lower 48!
Thanks
Offline Trackpad
« Reply #62 on: December 06, 2012, 05:53:17 AM »
Glad to help, Mark. The model is the old Airfix kit. I'd recommend a newer, better one! ;D
Cheers!
« Reply #63 on: December 06, 2012, 08:02:27 AM »
Sorry for the confusion- only meant a great set up and a fridge close by is a model builders dream - nothing more. I dont have that set up so was joking I would move in....Des deleting the post is understandable. Sorry if I offended.
Offline Trackpad
« Reply #64 on: December 06, 2012, 08:10:10 AM »
Hey, Steve,
No worries, mate, and no apologies required. Thanks for the clarification: I just wasn't too sure of the comment's direction. No offence taken: you're still welcome to drop by for a Spitfire Ale, as are all other Forumites here!  8)
Cheers!
« Reply #65 on: December 06, 2012, 10:19:39 AM »
. . . welcome to drop by for a Spitfire Ale, as are all other Forumites here!  8)
I'll pass on the beer but if you have any cold pizza in there, well, that's another story!
Offline Trackpad
« Reply #66 on: December 06, 2012, 12:20:32 PM »
Sure thing, Chris: fresh from the Italian Front!  ;)
Cheers!
« Reply #67 on: December 06, 2012, 12:30:22 PM »
My Gawd, free beer and (cold) Pizza; a Fighter Pilot's dream! Might make re-locating to ON.  attractive even to me! Seriously, with company like this how can I go wrong?? Really look forward to running into you Guys somewhere "down the road".
Count me in!
Lance :)
Offline Trackpad
« Reply #68 on: December 06, 2012, 01:52:05 PM »
Hey, Lance: you're in? Take a look at our respective avatars: I just made Hero Member, how many months behind you and Chris? By that count, I'm the rook here!   ;D
Cheers!
« Reply #69 on: December 06, 2012, 10:36:55 PM »
  Congratulation my old friend for reaching Hero Member statis.
Offline Trackpad
« Reply #70 on: December 06, 2012, 11:26:04 PM »
Thanks, Gregory. Does this means we get "medals and tea," or does it mean that we have to work that much harder??  ;D  ;D
Cheers!
« Reply #71 on: December 06, 2012, 11:38:49 PM »
Unfortunately, in my case it just means that I have keyboard diarrhea.
« Reply #72 on: December 07, 2012, 12:29:27 AM »
    No Gary, it's cold pizza and Spitfire Ale as we agreed earlier; as for the working thing we both are semi-retired so that can't apply........
Cheers! ;)
« Reply #73 on: December 07, 2012, 06:16:11 AM »
  Gary,
LOL no metals and tea,but you do have to learn the secret hand shake though.
« Last Edit: December 07, 2012, 01:47:24 PM by GAJouette »
Offline Trackpad
« Reply #74 on: December 07, 2012, 10:01:19 AM »
Well, with everything else that's been going on in this thread, I guess I'd better post a new update! In no particular order, here's what has happened over the past few days:
a. external firewall sprayed with Krylon Gloss Black, then sprayed with Alclad 2 Duralumin.
b. forward cowling sprayed with Xtracolor Medium Sea Grey, a dead ringer for Battleship Grey.
c. filled and sanded a shallow step on the fuselage underside between the "floor" of the cockpit assembly and the lower fuselage surface.
c. I've been tweaking Xtracolor RFC Green with some light tan and sand to give it a bit more of a brownish tinge. I'll probably spray this new mix on the underside of the fuselage tomorrow to see what it looks like. If it's in the ballpark, I'll apply it to the rest of the fuselage in a couple of days (once the underside dries out).
e. And I've made my first small goof in the build:
See the problem? If not, neither did I. With the lower fin extension in place, I figured I'd fit the upper fin: get 'em both done at the same time, don'tcha see? Three days later I belatedly realized that the horizontal stabilizer had to be fitted before the upper fin. See the little vertical tab blocking the slot for the horizontal stab?? That's the problem!!
The solution? Surgically remove the offending tab, eventually fit the horizontal stab, and replace the tab with short length of appropriately-sized styrene strip. Hey, presto! No one but you and I will ever know I goofed!  ;D
« Last Edit: December 07, 2012, 12:00:53 PM by Trackpad »
Cheers!
