Author Topic: TP's WNW 1/32nd Scale Biff  (Read 56067 times)
Re: TP's WNW 1/32nd Scale Biff
« Reply #30 on: November 22, 2012, 07:57:28 AM »
Here's looking at Gary's Biff, kid!
Offline Trackpad
« Reply #31 on: November 22, 2012, 08:19:59 AM »
Well, chaps, what can I say except "The drinks are on me!" Bottoms up, and thanks for the encouragement!  ;D
Cheers!
« Reply #32 on: November 22, 2012, 08:41:47 AM »
   Save a seat for me!
« Reply #33 on: November 22, 2012, 12:31:22 PM »
Looking good TP!  I just came back from the bar as I have a long weekend ahead of me.  Even my son wants to go to the hobby shop on Friday, first time for us in ages.  I am looking forward to it.  May even take some pics to commemorate the event.  Have a joyous weekend and remember the model will always be there, enjoy your time with your family.
Offline Trackpad
« Reply #34 on: November 25, 2012, 02:37:35 AM »
Hello, Mark,
Thanks very much for your support. I hope you had a great time at the hobby shop with your son!
So: I'm back. Let the mayhem and chaos continue!  ;D  ;D
Cheers!
Offline Trackpad
« Reply #35 on: November 26, 2012, 12:41:25 PM »
Just a mini-update to start the week. I got the mainplanes separated and sanded/cleaned up late last week, and I've just finished attaching the ailerons to the lower wing: taking a break from the cockpit. The upper ailerons will go on in a day or two, then I'll either revert to cockpit mode or give the wings a first coat of paint. Photos around the end of the week. How do you spell "glacial" again??  :o
Cheers!
« Reply #36 on: November 26, 2012, 02:06:11 PM »
   Gary,
Glacial is fine as long as there's progress. Looking forward to seeing the next progress photos my old friend.
Offline Trackpad
« Reply #37 on: December 03, 2012, 12:08:41 PM »
And the glacial build continues!
Three elements of an update this evening (I'm still in the"weekend," so update as promised!). First, here is the completed cockpit interior. It's a finicky, detailed structure but it looks the part once completed. Hardest part was fitting the rudder control wires from front to back along the sides: the bracing wires kept getting in the way! The rest went well, but I was continually touching up the PE parts where I'd scratched a bit of paint off here and there, or missed a spot altogether:
Next, the fuselage is together as per the instructions. Des fitted the cockpit interior to one side of the fuselage, then attached the other side. I went with the recommended route because I feared damage to the interior during the filling and sanding process. Sanding the rear of the fuselage was a bit of a nuisance because of the four PE parts jutting out of the structure. But that's why God created thin sanding sticks!
And finally, if you really need a photo of two wings ( :)) ), here they are, drilled for rigging, sanded, and with reinforced (with thin brass wire) ailerons fitted. I made sure that the wing structures were solidly glued to the respective centre sections: fair bit of weight for them to support:
I hope to get the fuselage closed up this coming week, maybe get a bit of paint applied, and maybe get the u/c and lower wing fitted. Not yet dead certain of which line of paint to use: Xtracolor (my favourite), or possibly the Misterkit line. Any thoughts on this question would be most welcome. Next update: next weekend at the latest. Thanks for visiting!  8)
Cheers!
« Reply #38 on: December 03, 2012, 12:16:04 PM »
Nice work. Looks like the next big step is coming.
« Reply #39 on: December 04, 2012, 07:59:42 AM »
   Nice update Gary, and now you are growing real small in my 12 O'Clock position, quite a lead on me as I'm still stalled out with other "things" that must be done. Very fine results so far, looking forward to your next chapter.
Lance ::)
« Reply #40 on: December 04, 2012, 09:23:11 AM »
Beautiful looking office you have there Gary! I'm looking forward to seeing you button up the fuselage around it. Speaking of the fuselage, it's an odd looking ugly duckling to me but then again, no one could really say that the Biff is anything like an elegant looking design.
Offline Trackpad
« Reply #41 on: December 04, 2012, 10:03:19 AM »
Well...again out of character, I got the office into the fuselage late last night: started fiddling with it, and there it was, home free. I needed a bit of filler around the fuselage/floor join seam. I think it was because the curved surface of Part A23 above the Vickers gun fits between two raised "lines" inside the forward fuselage. But the tolerances are very fine, and my paint might have caused that part to "not fit" between the lines. I'd suggest that you sand down and thin out a bit of that curved portion: not much, but enough that it will fit properly. Maybe if you tape the fuselage halves together and then do a dry fit with A23, you'll see if you might have a small problem. Mind you, the gaps I got were small, easily filled with a bit of thinned white glue. With any luck I'll be able to splash on a bit or RFC Green by weeks' end.
BTW, I'm going with Xtracolor paint. I find that the Misterkit version of RFC Green is too green and too light for me. But then, no one can ever accuse me of being perfect!  :D
Cheers!
« Reply #42 on: December 04, 2012, 11:16:23 AM »
  Gary,
Another outstanding update my old friend. Just as I would expect from your talented brench. Awesome details.
Offline Trackpad
« Reply #43 on: December 04, 2012, 12:40:39 PM »
Hello, Gregory,
You are too kind, old friend, but I thank you for your comments. They are very much appreciated!
Cheers!
Offline Whiteknuckles
« Reply #44 on: December 04, 2012, 01:07:08 PM »
Excellent pit Gary - looks very smart.
Eternal Apprentice
