Author Topic: TP's WNW 1/32nd Scale Biff  (Read 56072 times)
Offline Trackpad
Re: TP's WNW 1/32nd Scale Biff
« Reply #45 on: December 04, 2012, 03:37:52 PM »
Excellent pit Gary - looks very smart.
Many thanks, Andrew!
Cheers!
Offline Epeeman
« Reply #46 on: December 05, 2012, 08:17:14 AM »
Gary,
Trying to catch up with everybody's GB so apologise for late entry here.
Looks a really nice, tidy (busy!) office you have got together there.  Is this WNW kit going together well so far?
« Reply #47 on: December 05, 2012, 09:32:43 AM »
Hello Gary:  I am catching up on all the builds as well.  This is looking pretty nifty, the cockpit details look the part.  I have this kit, but it seems rather daunting and am waiting a little longer to build it.  I think it is a neat airplane and look forward to seeing you progress through this one.
I like the Tamiya acrylic line.  I was a dyed in the wool Testors Model Master user, but the darn lids would glue themselves onto the jar after a few uses.  I use Tamiya almost exclusively in concert with Methyl Ethyl Ketone (MEK) for thinner.  I use MEK for cement; I put it in old Testors cement bottles, I use it for brush cleaner, and it can be used with Tamiya putty as a thinner to get a slurry into a small crack rather than try to cram the putty itself in there with limited results.    I used Xtracolor years ago, but it seemed to take forever to dry.  What are your experiences with it?
Offline Trackpad
« Reply #48 on: December 05, 2012, 11:48:23 AM »
Hey, Mark and Dave!
Dave, the kit goes together really well. the cockpit is a bit "busy," so I'd suggest that you first determine what extra bits and bobs you want to fit, then work out a plan to fit them, then start the build. I didn't, started, and then decided to fit the rudder control cables, by which time I had the rigged side panels in place. It was just so much fun trying to chivvy my lengths of EZ Line from back to front along the minimal space between the side panels and the fuel tank! The only other minor problem I had was that the assembly didn't fit exactly into the fuselage: I got very small gaps at the front of the structure. But they were easily filled with thin white glue.
Mark, I really like Xtracolor, even though it takes a day or so to dry. I work this requirement into my schedule: paint one day, do other things on the build the next, and continue painting the day following. I usually use a 2:1 ratio of thinner to paint, with the thinner being lacquer thinner. This lays down good coverage, virtually no puddles (unless I'm particularly stupid) and the paint is pretty much dry the next day. BTW, I've tried the Xtracolor thinner, and that does require care in spraying because it does not "gas off" as fast as lacquer thinner, and so you have a much better chance of "puddling." I've used it from a 2:1 ratio down to about 7:1 for shading, applied at about 16-18 psi through an Iwata HP-C airbrush. Here's a photo:
Everything you see on this Spitfire is painted on, less the stencilling: cam pattern, weathering, squadron codes, serial numbers, national markings...everything, all with Xtracolor. For me, it just really works well. I do have other paints in the armoury, though: Modelmaster,Tamiya, Gunze, White Ensign, Alclad 2, Testors and Misterkit. I use these for specific builds or particular details, and they work all right for me. But if I were to go with just one line, it would be Xtracolor. Unfortunately, I have to buy it from the UK. Fortunately, having attended a few UK Nationals, I have enough here to float your normal-sized RCN corvette! Hope this blathering helps a bit!  ;)
PS: The Spit is a Canadian subject, and the Spitfire ale just sort of "turned up...!"  ;D
Cheers!
« Reply #49 on: December 05, 2012, 12:13:00 PM »
I'll have one of those...the Spit is nice too!
Offline Trackpad
« Reply #50 on: December 05, 2012, 12:15:14 PM »
I forgot to mention that I use a paint booth and a paint mask, primarily because of the lacquer thinner. And, as you can see, it vents directly outside: safety first! I can store my paint in the booth, thus allowing me to do mixing and thinning prior to airbrushing with the blower on: no excess fumes getting into the rest of the house -
I decided to build mine because I found that the commercially available booths were just too small. I found that out for sure when I caught the Wingnut virus, not to mention contract builds for things like the Tamiya 1/48th Lancaster. The booth is is a mix of lumber, dryer hose, squirrel cage blower, filters, and paint. But it works!  8)
« Last Edit: December 05, 2012, 12:18:31 PM by Trackpad »
Cheers!
Offline Trackpad
« Reply #51 on: December 05, 2012, 12:17:45 PM »
Apparently,  this used to be available only over Christmas. Recently it has become more or less a staple of the LCBO. C'mon by, Steve: there's a cold one here for you!  ;D
Cheers!
« Reply #52 on: December 05, 2012, 12:18:22 PM »
Nice set up. Everything close at hand....except the beer fridge....
Offline Whiteknuckles
« Reply #53 on: December 05, 2012, 01:36:11 PM »
...squirrel cage blower....
Forgive my ignorance, but this is a bit of kit I'm not familiar with Gary..... 8)
Eternal Apprentice
Offline Trackpad
« Reply #54 on: December 05, 2012, 02:09:28 PM »
Actually it's just out of frame, stage left!  ;D
Cheers!
Offline Trackpad
« Reply #55 on: December 05, 2012, 02:21:08 PM »
Hi, Andrew,
"Squirrel cage" is an unofficial term for a centrifugal fan, called as such because they can look like a hamster's exercise wheel. Here's a link about them:
http://en.wikipedia.org/wiki/Centrifugal_fan
In my photo it's the big black thingie on top of the booth itself. It draws the fumes and paint overspray upwards within the booth, drawing the air through a replaceable filter (removing paint and dust, thus protecting the blower) and blowing it through the dryer hose and out into the North American atmosphere. They're pretty quiet: when on, my wife standing in the kitchen directly above the booth can barely hear it running.
I've got it wired so that it starts up whenever I turn on the main booth light, the white bar across the booth opening. The little black light is used when I just want to check paints and supplies, but not actually do some painting. Hope this helps!  :)
Cheers!
Offline Trackpad
« Reply #56 on: December 05, 2012, 02:40:58 PM »
Steve, because I have some spare time...
One beer fridge, tactically sited, and very close at hand. One of the reasons that I'm glad to be retired: I could set up the modelling area my way, knowing that it would not be stripped down in three or four years! ;D
Cheers!
« Reply #57 on: December 05, 2012, 03:10:13 PM »
Ha! there you go, I thought you missed a comma between squirrel cage and blower in the relevant post!! ;D ;D
(I certainly know what a centrifugal fan is).
The only thing about your fridge is that the door opens the wrong way ;)
Eternal Apprentice
Offline Trackpad
« Reply #58 on: December 06, 2012, 03:51:48 AM »
True, but I'll accept that minor penalty: the fridge fits too neatly between the HRV and the paint booth. Besides, I can't have the ale too conveniently placed. That might have a "marked deleterious effect" on my modelling. Perish the thought!  ;D  :D  ;)
Cheers!
« Reply #59 on: December 06, 2012, 05:15:40 AM »
...this becoming model builder porn...Im assuming you're beyond wanting to adopt.
