Author Topic: 1/32 WNW Sopwith Pup RNAS  (Read 22610 times)
Re: 1/32 WNW Sopwith Pup RNAS
« Reply #45 on: June 28, 2019, 06:23:06 AM »
I thought it was just extremely fine wood grain!    ;D
Uhhh yeah let's go with that!  ::)
Ryan
Works for Me  8)
Offline Ryan
« Reply #46 on: June 28, 2019, 10:13:40 PM »
Here we have the metal parts painted with Vallejo Model Air applied via brush. The pre-thinned model air flows very nicely off the brush.
It's not as smooth as I would like and I might go back and try a different technique for metal parts that I will describe. I have placed the stripping agents on high alert while I ponder the look of the part.
Pup by The 3rd Placer, on Flickr
Ryan
Upcoming: Not sure!
« Reply #47 on: June 28, 2019, 10:26:47 PM »
Personally I think it looks great! I would leave it as is but it is your Model  ::)
Offline Ryan
« Reply #48 on: June 30, 2019, 11:42:21 AM »
Regular visitors to my build threads will note I won't hesitate to strip a part if I feel things are going south.  :-\
Well I wasn't too happy where the IP was going so I restarted, I'm glad I did so. I repainted the panel except this time laid down a pre shade of Tamiya Rubber then the top coat. I normally pre shade all of my interior parts on a non WWI subject as the shading helps the wash blend a bit better, in the pic below you can see by spraying directly at the part broad side you can retain some of the pre shade around the edges of the details on the piece. The rest of the sequence is the same as described above with the exception of the aluminum bezel, this time I dry brushed the detail with MM Aluminum Metalizer. The brass bell was done with Vallejo Model Air Aluminum brush painted with a watery Vallejo Brass applied over it. Crank is also dry brushed.
And here is the finished, cleared part ready for decals.
And actual size.
Thanks
Ryan
« Last Edit: June 30, 2019, 11:49:50 AM by Ryan »
Upcoming: Not sure!
Offline Ryan
« Reply #49 on: June 30, 2019, 12:16:00 PM »
Got more internals complete too, the fuel tank and seat mount were added.
Ryan
« Last Edit: June 30, 2019, 12:21:34 PM by Ryan »
Upcoming: Not sure!
« Reply #50 on: June 30, 2019, 01:02:56 PM »
Very nice work, Ryan!  I like your use of washes.
« Reply #51 on: June 30, 2019, 03:46:21 PM »
That’s stunning Ryan!
Top notch  :)
« Reply #52 on: June 30, 2019, 11:40:04 PM »
The interior is looking great! I like your panel re-work.
Offline Ryan
« Reply #53 on: July 01, 2019, 10:12:21 PM »
Thanks folks, I'm glad I took the time to redo the panel.
All that is left is the seat and some misc. X rigging and I can call the cockpit module complete.
Ryan
Upcoming: Not sure!
« Reply #54 on: July 01, 2019, 10:46:13 PM »
Very clean and neat interior.
« Reply #55 on: July 03, 2019, 07:52:53 PM »
Nice re-do!!
Offline Ryan
« Reply #56 on: July 03, 2019, 10:09:33 PM »
Many thanks folks, looking to get a bunch done over the next few days.
Ryan
Upcoming: Not sure!
« Reply #57 on: July 11, 2019, 11:16:46 AM »
Second panel turned out even better Ryan .
Offline Ryan
« Reply #58 on: July 11, 2019, 10:17:38 PM »
Thanks Terri, I was pleased with it too.
Ryan
Upcoming: Not sure!
« Reply #59 on: July 12, 2019, 05:41:28 AM »
   Really nice work Ryan, I particularly like the clean job you've done on the Flight Control rigging. She's going to be an absolute stunner!
