Author Topic: Completed - Wingnut Wings Roland C.II - COMPLETED!  (Read 41565 times)
Re: Wingnut Wings Roland C.II
« Reply #75 on: May 08, 2019, 09:20:53 PM »
Looks excellent sitting on it's gear!
« Reply #76 on: May 08, 2019, 09:40:34 PM »
Wow! this is really looking great, Eric.
Offline Europapete
« Reply #77 on: May 08, 2019, 11:18:48 PM »
Best Roland out there, great build Eric, well done. Regards Pete in RI
« Reply #78 on: May 09, 2019, 03:27:48 AM »
As others have written that looks excellent on the u/cand with the prop.
Stephen
« Reply #79 on: May 09, 2019, 11:39:22 PM »
Eric the build is marvellous but the paint and its finishing looks really awesome!
Antonio
Offline eclarson
« Reply #80 on: May 11, 2019, 09:49:49 AM »
Thank you all for those encouraging comments!
Attention now turns to the flying surfaces starting with the tail planes.  After priming with white Stynylrez primer, pencils were used to draw the internal ribs (drafting pencil with 4B lead for the underside, a Raw Umber art pencil for the upper sides) after which MRP Bleached Linen paint was airbrushed in multiple light coats.  The goal is to simulate the effect of translucent linen with light shining through from above, hence the darker lines on the bottom, but I also wanted to show a hint of the ribs on the top side.   On the other hand, the scumble finish will also be applied to the tail and wing top surfaces so those ribs may not be visible when all is said and done.
Eric
« Reply #81 on: May 11, 2019, 10:29:48 AM »
I like it Eric , I have been adding the use of pencils/crayons for this effect and I'm rather pleased with the results so far . Looking forward on seeing the scrumble camo applied . The hint on the ribs will be and should look great .
Offline eclarson
« Reply #82 on: May 11, 2019, 10:50:37 AM »
Thanks Terri!  I forgot to mention that appropriately, I learned this technique several years ago from Des' modeling page.
https://www.ww1aircraftmodels.com/page9.html
Eric
Offline aliluke
« Reply #83 on: May 11, 2019, 10:57:03 AM »
Wow! This is becoming a stunning model. I have one in my stash and this log will now be the reference and gold standard.
Alistair
Offline Edo
« Reply #84 on: May 11, 2019, 04:12:37 PM »
what a beauty!!
« Reply #85 on: May 11, 2019, 09:10:23 PM »
Excellent results using the pencil! Even better knowing you picked it up from Des.
Offline eclarson
« Reply #86 on: May 13, 2019, 11:25:00 AM »
Got the ribbing done on the lower wings today.
Eric
« Reply #87 on: May 13, 2019, 11:30:38 AM »
Simply superb!
« Reply #88 on: May 14, 2019, 12:10:36 AM »
That’s a very nice technique. I really like your wings.
« Reply #89 on: May 14, 2019, 11:51:42 AM »
Very nice effect . Turned out super Eric  :)
