Author Topic: Completed:WNW Fokker DVII 1/32nd scale: Jasta 4.Ernst Udet "DU Doch Nicht"  (Read 75885 times)
Re: WNW Fokker DVII 1/32nd scale: Jasta 4.Ernst Udet "DU Doch Nicht"
« Reply #90 on: May 24, 2019, 11:59:45 AM »
I can see why you wanted to replace the first engine, Amigo.  It looked a little blurry, kinda out of focus.  Just kidding.  It looked fantastic, but the second one looks even better!  Love it!
« Reply #91 on: May 24, 2019, 05:35:22 PM »
Very nice engine, the weathering looks realistic and the wiring is superb.
Good work,
Bye,
« Reply #92 on: May 24, 2019, 10:45:07 PM »
Thanks Bud! I noticed the slightly out of focus stuff but too late to correct now  :-[
Good work,
Bye,
Thanks Manni!
« Reply #93 on: May 24, 2019, 11:21:09 PM »
Another nice one from the Fokker Factory. Name change to Anthony?
« Reply #94 on: May 25, 2019, 06:28:40 AM »
Very nice fuselage, Rick. I love the red.
« Reply #95 on: May 25, 2019, 10:12:02 AM »
[SEE Buds'  original post of May 21 at 11;55;07AM]
Rick,
High praise from our Amigo, he has seen my streaking in person and from what I see on the DVII, he is 100% correct !
« Last Edit: May 25, 2019, 10:16:23 AM by dr 1 ace »
« Reply #96 on: May 25, 2019, 10:17:47 PM »
Thanks Steve  ;D
Thanks Andreas. The red is a mixture from a couple of Valejo reds.
Rick,
Thanks Amigo. Personally I still think you are the Master!
and the base coat of red is applied:
« Reply #97 on: May 26, 2019, 08:25:05 AM »
One step forward and one step back! I managed to add the engine and radiator lower cowl assembly. While doing so the two triangular panels that had been carefully filled and sanded broke loose. So now to sand, refill, sand, and repaint that seam >:(
« Reply #98 on: May 27, 2019, 11:18:40 PM »
The slight mishap of the detaching triangular panels was sanded, filled, and sanded again. Then re-painted. Last the forward panels are all attached:
« Reply #99 on: May 27, 2019, 11:37:25 PM »
Great recovery Rick, looks great.  Sad that the beautiful engine will be hidden behind panels.  Looking forward to your adventures.
« Reply #100 on: May 28, 2019, 12:26:22 AM »
Hi Rick - just caught up with this one. Very nice work indeed.
« Reply #101 on: May 28, 2019, 12:33:43 AM »
Thanks Juan, I appreciate the comments! The engine will be even more covered up once the troughs are installed. Virtually nothing is seen  ::)
Thanks for dropping in and the comment Gary!
« Reply #102 on: May 28, 2019, 03:22:25 AM »
Saved in true Rick style. Well done that man!
Keep on keeping on Amigo  ;)
vB
« Reply #103 on: May 28, 2019, 04:08:12 AM »
vB
Thanks vB, True Rick Style... Screw something up and recover  ;D
« Reply #104 on: May 29, 2019, 06:31:11 AM »
I have worked in some contrast in the red and black using oils. Two shades of red oils blended in and burnt umber on the black. Once glossed and markings are applied I will go back with some Earth Tones in oils and Pastels.
