Author Topic: 1/32 Gotha G.I Scratchbuild  (Read 27424 times)
Re: 1/32 Gotha G.I Scratchbuild
« Reply #75 on: March 23, 2019, 12:31:57 AM »
Glad you are moving on with this beauty, I know WNW had this in the works for a while, but credit your inspirational build with having them release this model.
guitarlute101
« Reply #76 on: March 23, 2019, 02:17:26 AM »
Thanks everyone!
I've been putting some thought into my build now and I think I'll be amending it a little.
I will definitely be building the WnW Gotha G.I, I am so impressed that they have released it for everyone to enjoy! Just so I don't have an overlapping build I will be changing mine slightly to model the 1st incarnation of the G.I called the "Friedel-Ursinus Type FU". This way I can have the Friedel and the G.I in my collection.
WnWs release of the Gotha G.I is perfect timing for the stage that I am at in my build as I can easily convert it to the FU without much modification at this point in my build. I am very pleased with how accurate I was able to make the center cockpit area in comparison to the WnW kit and instructions but the FU version had a few variations.
The FU had a different cockpit covering, engines, tail and wings than the G.I.
The cockpit covering was a simpler design and there were a few redesigns along the way.
One particular variation is the engines. The first version had the radiator in the engine nacelle and the nacelle was a little "boxy"
I'm going to go with the second version with exposed engines and Hazlet radiators so I can really detail them up.
Onward and upward!
Thanks so much for looking in and the encouragement!
« Reply #77 on: March 23, 2019, 05:58:13 AM »
With exposed engines and radiators that is going to be quite a challenge - and quite a model when finished!
Offline Trackpad
« Reply #78 on: March 23, 2019, 07:39:11 AM »
Hello, Mark,
Congratulations on your project to date. Excellent work that puts me so far into the shade that I need a spotlight at high noon! Best of luck to you as you move on with this most enjoyable build: your enjoyment to build and our enjoyment to watch how you do it.  8)
« Last Edit: March 23, 2019, 10:16:22 PM by Trackpad »
Cheers!
« Reply #79 on: March 23, 2019, 04:28:02 PM »
It's a courageous decision to increase the challenge of this build with so many additional details. On what you already made I'm sure it will be something really special. Great choice!
« Reply #80 on: March 24, 2019, 04:27:22 AM »
Excellent idea! Your skills are sure to pull off a winner!
guitarlute101
« Reply #81 on: March 26, 2019, 07:10:10 AM »
Thanks everyone,
I've spent a few days looking at the Ursinus and am still not quite sure about how the control lines for the flying surfaces are arranged for it.
I think I will be putting the build in a short holding pattern for now with the hopes that Windsock will release a "Gotha at War" volume that has more pictures or even better, detailed scale drawings! If nothing pops up in that department soon then I'll just continue the build the best I can.
More soon,
« Last Edit: March 26, 2019, 09:33:00 AM by guitarlute101 »
Offline Lozenge
  • Build models or make war...
« Reply #82 on: June 03, 2019, 04:17:20 PM »
Hy Mark, great work you do. If you are going to paint the switches in brass, I can just say: Do use one of the Citardel colours with their fine metallic pigmentation... it's the finest without spraying in a deco acryl metal.
Great work you do! Thanks for sharing your results from your hobbyrooms silentium.
"Well, how'd you do, Private William McBride?
Do you mind if I sit here down by your graveside?"
Eric Bogle - "No man's land"
« Reply #83 on: August 11, 2019, 09:57:58 PM »
How goes the battle on this one ?
