Author Topic: 1/72 Fokker Dr.1 (spinning prop update - take 2)  (Read 5077 times)
« on: December 27, 2018, 02:00:00 AM »
Hi,
I’ve finished the 1/72 Eduard Fokker Dr.1 - phase 1 at least; part of a master plan to encase it in flight, in resin!
Build thread here:
https://forum.ww1aircraftmodels.com/index.php?topic=10016.0
The ‘spinning’ prop, streamers & scarf will be added just before entombment...
Thanks for following along  ;)
« Last Edit: January 23, 2019, 05:11:19 AM by Gisbod »
Re: 1/72 Fokker Dr.1 (phase one complete)
« Reply #1 on: December 27, 2018, 10:15:56 AM »
Amazing! You worked on this for what, a week  ;D I am glad you took the photos and certainly hope phase 2 goes well. Otherwise you will have a blob of distorted plastic and paint instead of this Nicely Done DR1  8)
« Reply #2 on: December 27, 2018, 06:52:10 PM »
Thanks Rick  :) hope you had a nice Christmas...
Yes, that’s the (probable) reality!
I’ve just bought Eduard’s 1/72 Dual Combo Nieuport 17 - so I can make one (nicely) and bung the other one together to experiment with...
« Reply #3 on: December 27, 2018, 07:41:29 PM »
Ps I’m signed off flying at the moment (nothing serious) and I seem to be racing through kits!
« Reply #4 on: December 27, 2018, 08:02:52 PM »
Nice little tripe, I cross my fingers for phase two and wait to see the completed prject.
« Reply #5 on: December 31, 2018, 11:15:13 PM »
Even in this small scale this model seems to be a Dr.I - mission accomplished!
In a time, I would need to unpack the kit :o
Wait now for the completed project :-*
« Reply #6 on: January 01, 2019, 02:37:10 AM »
Phase one looks great, looking forward to phase two.
« Reply #7 on: January 01, 2019, 05:32:16 AM »
Still waiting for the resin companies to re open from Xmas...
« Reply #8 on: January 01, 2019, 07:37:19 AM »
Same here, but then I have a special attraction to Dr.1s regardless of scale!
Re: 1/72 Fokker Dr.1 (Spinning prop update)
« Reply #9 on: January 23, 2019, 01:56:34 AM »
Sooo,
It’s taken me quite a long time to research the resin - I’ve finally tracked down what I need to complete the project and will hopefully be casting this week or so.
I’ve made a stab at the spinning prop... it looks quite good when you’re just looking at the model overall, but i admit that it looks a bit cartoonish if you look at the close ups  ::) (but then it is 1/72...)
Do you reckon that’s ok?
I might still experiment with just a clear plastic version? Like Prze’s post in the build log. What do you think? I’m completely open to options...
Re: 1/72 Fokker Dr.1 (spinning prop update)
« Reply #10 on: January 23, 2019, 05:10:54 AM »
On reflection, I didn’t like the last prop in the close up photos...
I’ve had another go...
Re: 1/72 Fokker Dr.1 (spinning prop update - take 2)
« Reply #11 on: January 23, 2019, 08:47:26 AM »
Guy,
   I like the second attempt far better. I believe a clear disk with an "almost clear" prop on it would be the optimum portrayal although I don't know if the clear disk would show once in resin? Bottom line though, looking like one heck of a fine paper weight!
« Reply #12 on: January 23, 2019, 06:19:31 PM »
Thanks for the feedback!
Yes, the first one looks like it was done by a 5 year old!  ???
I’m still experimenting.. stand by for updates.
« Reply #13 on: January 24, 2019, 01:19:58 AM »
The second version seems to be better, but it's hard to say with macros.
Could you please add a picture with more distance, so the whole airplane is visible? Gives may be better impression ...
« Reply #14 on: January 24, 2019, 03:13:21 AM »
Will do Frank, but I’ve just applied some resin to the interior so need that to cure first. I’ve posted my 3rd attempt on the under construction section ‘Flying Fokker’...
