Author Topic: Eduard 1/48 SE5a Nightfighter  (Read 8890 times)
Offline aliluke
Re: Eduard 1/48 SE5a Nightfighter
« Reply #15 on: December 09, 2018, 06:11:11 AM »
Hi Guy
That is spectacular - incredible detail. Can't believe it is 1:48!
Alistair
« Reply #16 on: December 10, 2018, 12:39:56 AM »
Thanks Alistair  :)
It’s taken longer than I thought to get to the painting stage. It’s not difficult, but it is fairly complex for this scale. The attention to detail is excellent! The gunsight is particularly nice.
I’m trying to make as much as I can prior to painting...
« Reply #17 on: December 10, 2018, 04:11:00 AM »
Your speed with this complex kit is impressive - you doing things in a week for which I need a month :o
« Reply #18 on: December 10, 2018, 04:47:22 AM »
That’s just because you do yours properly Frank!
Super kit isn’t it?
« Reply #19 on: December 10, 2018, 07:50:38 AM »
Super kit isn’t it?
Yes, as I said in my build report. All the nice little things you can only notice, if you build this kit yourself :)
The right kit to celebrate the 25th anniversary of Eduard :-*
Have fun with painting,
« Reply #20 on: December 10, 2018, 08:01:16 AM »
Thanks, will do Frank  ;)
In this picture there seems to be a thing hanging under the cockpit area (just below and forward of the fuselage roundel).. a terminal for an external wire to the Holt Flares?
Any thoughts?
« Reply #21 on: December 10, 2018, 08:53:50 AM »
Outstanding work. Your SE is looking gorgeous!
« Reply #22 on: December 12, 2018, 12:16:31 AM »
Thanks Rick  :)
I’ve got some paint on - I wasn’t quite sure of the NIVO colour, in the end, I plumped for MRP RAF dark green with a dash of PC10. I’ve no idea how accurate it is. More of a guess! The MRP paints are fantastic - super smooth. Undersides are MRP doped linen with the ribs highlighted with a mix of off white.
Glossed with Tamiya clear and ready for decalling and further effects.
Thanks
« Reply #23 on: December 12, 2018, 08:59:11 AM »
Looks excellent to me. Never tried to paint Nivo 8) The paints do look very smooth. I really need to try more brands.
« Reply #24 on: December 12, 2018, 07:01:13 PM »
Thanks again Rick  ;)
Yes, I’d give the MRP a go, they are the best finish of everything I’ve tried to date. You need to mist on in layers to build up the opacity - but it dries almost instantly, so you can do it in one sitting. They’re not the cheapest, but they do a PC10 and various linen shades, so worth a trial at least.
She’s suddenly come on quickly! As I mentioned before, the Rib stitching effect was bothering me and, whilst I didn’t want to remove it, I did end up toning it down with a very light sanding with a very fine Tamiya sanding sponge (I love these for contoured surfaces!). It’s kept the detail but removed the pin like high points. To my eye, it’s a big improvement. It just takes the edge off the overly raised stitches.
The viewing ports for the internal control pulleys are very well represented, with clear parts and PE. I really like these.
I was worried about the decalling on the wheels (the red and blue circles are decals). I thought these wouldn’t look that good, but in the absence of a circle cutter for masking (I really must invest in one of these - any recommendations?) I went with the decals and was pleasantly surprised how well the came out. The one negative on the decals was I had a slight ghosting of a white surround from the printing being slightly out of register - surprised from a new Eduard kit. Particularly noticeable on the large wing roundels on a dark backdrop. Annoying, but I think I overcame it with some touching up with my breath held!
The telescopic sight is brass tubing, and I glazed the ends with ‘Glue n’ Glaze’ so you can even look through it with a little imagination!
The resin exhausts are exquisite!
‘Just’ the top wing attachment (my nemesis) and rigging and some other detailing to go. I seem to have lost the square windshield. I’ll keep looking, but may have to replace it with the (wrong) rounded one. I’ve also lost the Vickers gunsight  ???
Thanks again,
« Reply #25 on: December 13, 2018, 12:53:06 AM »
I’ve been fiddling with the Holt Flares.. tiny, about 3mm long. I’ve painted them black now, but I wish I’d painted the body of the flare then wrapped the unpainted PE around it  ::)
Just out of interest, I’ve found this ‘wonder glue’! It’s a super glue gel that has fast grip but has a bit of give too while drying. It’s in a dispenser than doesn’t gunge up. It’s transforned my modelling!
Brilliant stuff!
Offline Ryan
« Reply #26 on: December 13, 2018, 01:13:37 AM »
Nice and clean Guy, keep up the good work.
Ryan
Upcoming: Not sure!
« Reply #27 on: December 13, 2018, 02:31:47 AM »
Guy,
     Reference your request for recommendations on a circle cutter I have had good luck with the Olfa brand Model CMP-1, cuts great circles in decals and masking tape from 5mm radius to a full 3 inches. Inexpensive and I've used it for years.
https://www.amazon.ca/Olfa-9911-Compass-Circle-Cutter/dp/B000BK7NWC
« Reply #28 on: December 13, 2018, 03:31:51 AM »
Thanks Ryan,
And thanks Lance.. will get one of those.
« Reply #29 on: December 13, 2018, 04:41:16 AM »
Guy,
     A fellow in my Model Club has this one and it's a beautiful tool, however a bit pricey for my budget. I've tried it at a club meeting and it's most impressive, worth looking at perhaps.......
https://www.ebay.com/p/Dspiae-Mt-c-Stepless-Adjustment-Circular-Cutter-Craft-Tools-Toy-Hex-Wrench/19012541512
