Author Topic: Albatros B.II - Early-to Late conversion (1/32, Wingnut Wings)  (Read 18683 times)
Re: Albatros B.II - Early-to Late conversion (1/32, Wingnut Wings)
« Reply #60 on: January 10, 2019, 04:19:11 AM »
She is so beautiful, my eyeballs are exploding...... ;D
Offline NinetythirdLiberator
« Reply #61 on: January 10, 2019, 05:28:44 AM »
Mine too...now I can't see any more of these incredible models...
Dan  ;)
« Reply #62 on: January 10, 2019, 07:41:36 AM »
Thanks, Krow, Juan and Dan.
And I went further. The operation top wings began. I started with interplane struts. Since they are resin I decided to use 5-minutes epoxy glue Uhu to attach them, using the upper wings put on dry to control the geometry. In the first step I did only the outer ones and at that stage I had to secure the top wings with bottles of water to prevent their sliding forward. When the glue set I repeated the operation with the inner struts. Now the glue at all 8 locations will be left to set till tomorrow to reach the ultimate strength.
Tomorrow I will remove the upper wings, tie the landing lines in the inner bays at the cabane pyramid to have more space for manipulation and only after this I will glue the upper wings. Then the radiator, the exhaust and ... the rigging!!! The end is near.
« Last Edit: February 17, 2019, 01:22:45 AM by PrzemoL »
Offline Adam
« Reply #63 on: January 10, 2019, 09:36:09 AM »
Very fine method of fixing upper wings.  :)
Adam.
Offline KrzysiekK
« Reply #64 on: January 10, 2019, 04:54:19 PM »
Uhh..I thought I am the only one using such basic "jig" constructions:) Love that plane shape, which WNW shows in all delicious details
regards
K
Offline buzby
« Reply #65 on: January 10, 2019, 05:34:50 PM »
Hi Przemo,
I see that the Great Final is fast approaching   :)
finest modelling in all aspects
 8)
« Reply #66 on: January 10, 2019, 11:18:08 PM »
Looking absolutely brilliant !
« Reply #67 on: January 11, 2019, 01:30:28 AM »
Really amazing!
Offline jeroen_R90S
« Reply #68 on: January 12, 2019, 05:50:44 AM »
Looking good already, and glad I'm not the only one using whatever is around for a jig!
I like your undercarriage protector, too :)
« Reply #69 on: January 13, 2019, 08:46:58 AM »
Thank you, everyone.
Two days age the rigging started with a catastrophe, when I put the model upside down, to run the lower aileron cable, it fell from 10 cm height... But it was enough to loose two inner struts. One just jumped off its upper socket and the other one broke at its narrowest spot at the base. It surprised me, as the replacement resin struts are reinforced with steel wire, but it seems in this one at least the wire does not run along its entire length. Luckily, I managed to repair the damage without great problems. After that little nightmare, when I expected more obstacles, the remaining rigging went extremely smoothly. Two sessions divided by some fitting of the radiator with its pipes and my Poznań late Albatros was completed. The last bit to do was thinning down and removing the sink marks left by push rods on the inside of the taken off cowling covers. And now the model is indeed ready. It stands temporarily on a loose Polak grass sheet which will be its final base, I only have to order a suitable wooden frame to encompass it.
So, one final photo here, more in the gallery.
« Last Edit: January 13, 2019, 09:08:03 AM by PrzemoL »
« Reply #70 on: January 13, 2019, 09:06:53 AM »
A BEAUTIFUL Model and your usual expertise in finishes and rigging! Simply Brilliant!
« Reply #71 on: January 13, 2019, 10:58:15 AM »
In spite of your mishap, she is perfect in every way.  Absolutely stunning.
Offline jeroen_R90S
« Reply #72 on: January 13, 2019, 07:53:09 PM »
Nothing I can add to that -fantastic!
« Reply #73 on: January 15, 2019, 06:38:42 PM »
Thank you, gentlemen, I am glad you like my civilian Albie :-)
Offline Adam
« Reply #74 on: January 15, 2019, 11:21:44 PM »
Beautiful model.
Adam.
