Author Topic: Royal Aircraft Factory SE.5a, Eduard 1/48, 12.11.2018 The end  (Read 23363 times)
Re: Royal Aircraft Factory SE.5a, Eduard 1/48, 12.11.2018 The end
« Reply #60 on: December 13, 2018, 07:55:27 AM »
Oh my friends, with moving over to the completed section I missed your answers here, Sorry!
And what a great feedback, Thank you all! :-*
Can you explain how you attached the stretchers and PE control horns?
The stretchers and the control horns has some pins, or I cut them from the fret, that there is a pin remaining.
I drill the a very small hole (Eduard says 0.3mm, buit I use even smaller drills found some time ago on ebay, e.g. 0.26x mm)
The I mount the horn with CA gel into the holes. Here in Germany I found some gel with the name "100% Sekundenkleber" means 100% CA, which works great.
Thanks again for all your nice words!
« Reply #61 on: December 13, 2018, 09:51:13 AM »
Superb work Frank. One of the best SE5a models I have ever seen, I am in awe of your talents!
« Reply #62 on: December 14, 2018, 05:36:46 AM »
Thank you Dave! With all the nice WNW SE5a models around I need now a red face smiley!
I hope you will like my next biplanes too.
Offline Syd Solo
« Reply #63 on: December 14, 2018, 01:10:38 PM »
Terrific work, Frank. I have the Royal Class boxing of this kit and your build has answered a lot of questions for my future attempt at making it.
Syd
Offline phil2015
« Reply #64 on: March 21, 2021, 04:40:20 AM »
Sorry to keep digging up old build threads.  I'm absorbing so much from them.  This is a great build thread.
Re: the stretchers.  Did you thread them first, then glue the stretchers into the mounting points?  It has caused me to examine the kit closely and I see the spots where it's supposed to go. That's really elegant detail - does it work from an assembly point of view?
« Reply #65 on: March 26, 2021, 03:57:51 AM »
Thank you very much Phil, that is great feedback! So it is worth the effort of writing them.
Hmm, that was some time ago.
At least I drilled all positions before mounting. For the doubles there is a drilling template included.
I think I thread through one side, and glued already the other end to the end o the line (outside the model). Then glued both into the holes (secured with CA). After a short drying time I put tension on the rubber line and fixed it in the stretchers hole with a small amount of CA. Cut after 30 seconds or so drying time. That way you are not producing waste and your line last for more models :D
The SE.5a do not used turnbuckles!
Hope it helps,
« Reply #66 on: March 26, 2021, 04:19:03 AM »
This is a Great outcome, Frank, I am in awe! So much detail, so much to appreciate... Well done! Regards, Marc.
Offline phil2015
« Reply #67 on: March 26, 2021, 08:31:10 AM »
Hope it helps,
Absolutely, I get so much from your builds.  A challenge to try new things!
I get a lot from all the builds I see here.
Phil
