Author Topic: Roland C.II  (Read 14251 times)
Offline GB
Roland C.II
« on: August 05, 2018, 05:51:43 PM »
Continuining on from where I started with the engine - https://forum.ww1aircraftmodels.com/index.php?topic=9720.0 - have been beavering away with the interior of late and have now got to the stage where the fuselage is taking shape...
Base build is as per kit with the addition of of Modelkasten control lines, PE instrument bezel for the dial on the right facing the pilot, Taurus Models magneto and starting swtich and seatbelts cobbled together from the spares box with some lead wire.
Painted with acrylics and weathered with enamels, oils, washes and pigments.
Fuselage halves cemented together...
Wings dry fitted because I can  ;D
Re: Roland C.II
« Reply #1 on: August 05, 2018, 07:25:57 PM »
That interior looks great!
Re: Roland C.II
« Reply #2 on: August 05, 2018, 07:50:20 PM »
Very impressive work! I love the fine detailing. Keen to see further progress on this gem.
Re: Roland C.II
« Reply #3 on: August 05, 2018, 10:50:33 PM »
Gary,
    This is exceptional detail and quality of finish, I really like the results you've achieved here. I too will be following your progress closely, lovely work!
Re: Roland C.II
« Reply #4 on: August 05, 2018, 11:06:47 PM »
Yes! I could use this as reference, if I build my 1/48 one in the future. Fantastic!
Re: Roland C.II
« Reply #5 on: August 06, 2018, 12:37:49 AM »
Absolutely brilliant, Gary!  The interior is a masterpiece in and of itself.
Re: Roland C.II
« Reply #6 on: August 06, 2018, 01:27:31 AM »
Outstanding Gary, she is really coming along beautifully.
Re: Roland C.II
« Reply #7 on: August 06, 2018, 06:52:52 AM »
Wonderful interior of a great machine. I'll follow closely as this kit is high on my to do list...
Offline aliluke
Re: Roland C.II
« Reply #8 on: August 06, 2018, 03:47:19 PM »
Stunning as always Gary. Never been tempted by this one but that may well change as a I follow along.
Alistair
Re: Roland C.II
« Reply #9 on: August 06, 2018, 06:52:01 PM »
Really great interieur. I love the used look of the magneto.
Perfect!!!
Bye,
Re: Roland C.II
« Reply #10 on: August 08, 2018, 07:35:56 AM »
Great work. The seat belt drape is very realistic!!
Re: Roland C.II
« Reply #11 on: August 08, 2018, 07:49:07 PM »
Superb work on the interior. Always been tempted by this WNW kit, I think your build will only increase that temptation.....
Offline RUREDI
Re: Roland C.II
« Reply #12 on: August 10, 2018, 05:44:45 AM »
One of my favorite birds.  Watching with interest.  Thanks for sharing.
Rick
"I do not feel that I am fighting for France alone, but for the cause of all humanity, the greatest of all causes...I pay my debt for Lafayette and Rochambeau."  Kiffin Rockwell, Lafayette Escadrille
Offline GB
Re: Roland C.II
« Reply #13 on: August 12, 2018, 02:38:13 PM »
Thank you all  :)
Slight change of plan. Decided on a different scheme now so replaced the small header tank with teh larger one - adding the small coil pipe (some form of pressure relief valve??) using brass wire...
The underside of the wings will be finished in bleached linen and I wanted the ribbing and spars to 'show' through. So a little experimentation was undertaken.
Firstly I AB'd the wing with Tamiya XF-55. The rids etc were then taped and I oversprayed with White tinted with XF55. The tape was removed and further thin coats were added to reduce the 'harshness' of the intial XF55.
I was concerned that I was using too many coats of paint so tried a second option. I masked the ribbing etc befoe a light misting of the bleached linen colour. The tapes were then removed and I added further thin layes to blend in the ribs and spars.
As you can see from the photo, the two effects are essentially the same, but the top one (my 1st attempt) uses a lot more paint.I'm pretty happy with the overall effect considering it's my first attempt. Thoughts and comments are welcomed  ;D
Offline krow113
Re: Roland C.II
« Reply #14 on: August 13, 2018, 01:39:55 AM »
Nicely done details.
I think that would be an escape mechanism for the coolant system , an over flow outlet.
