Author Topic: Pfalz D.IIIa - von der Marwitz (1/32, Wingnut Wings)  (Read 13814 times)
Re: Pfalz D.IIIa - von der Marwitz (1/32, Wingnut Wings)
« Reply #15 on: June 11, 2018, 02:34:10 AM »
Your panel is awesome as is the interior and engine. Loving this one as usual!
Offline krow113
« Reply #16 on: June 11, 2018, 02:36:35 AM »
Very credible engine work.
Looks ,as usual, like a fresh production aircraft.
« Reply #17 on: June 11, 2018, 04:31:05 AM »
Exquisite Prze!
Great detailing...
« Reply #18 on: June 11, 2018, 10:59:58 PM »
Very nice progress!!
« Reply #19 on: June 13, 2018, 06:27:48 AM »
Thank you, your kind words are very much appreciated.
And here are more results of my recent modelling. The interior is basically finished and ready to be buried in the fuselage.
I have added HGW textile seatbelts with scratch-made springs. Besides this plumbing, wiring, control cables and some dirt not to have the model looking...
As reported by many more modellers earlier, the fit of the innards in the fuselage is very tight with the area in front of the cockpit prone to breaking when the pressure from the bottom wing is applied. I am thinking of an reinforcement of this position.
« Last Edit: October 24, 2018, 01:06:06 AM by PrzemoL »
« Reply #20 on: June 13, 2018, 07:10:33 AM »
Awesomw interior work as always! Moving along at a rapid pace
« Reply #21 on: June 13, 2018, 03:02:10 PM »
Superb additions!The interieur is turning out really good.
Bye,
Offline aliluke
« Reply #22 on: June 13, 2018, 03:15:09 PM »
Beautifully made, so clean and crisp. I'm all for newish look with only the lightest tint/hint of weathering. Your models always look like perfect minuatures of the real thing. Weathering is fine but I think it can overwhelm a model and become out of scale. Don't want to start an argument here but I reckon you have the balance exactly right. It is certainly the look I aspire too!
Alistair
« Reply #23 on: June 13, 2018, 06:03:06 PM »
Przemo,
    That interior looks sweet!  Glad to know about the interior tightness and the wings...  Will watch for that on mine.
Gaz
Offline krow113
« Reply #24 on: June 15, 2018, 03:07:23 PM »
LOL
Pretty good with the editing and all...
« Reply #25 on: June 15, 2018, 04:53:48 PM »
Looks great!
Borsos
« Reply #26 on: June 18, 2018, 06:54:04 AM »
Some more steps forward.
6 small turnbuckles for control surfaces and 16 big ones prepared with wire tails
Spandaus fitted with kit PE bits
The mounting points for ailerons, elevator and rudder reinforced with wire inserts
Fusellage innards closed, lower wing attached - a very tight fit here. I have reinforced the bridge on the fuselage top just behind the engine opening with a 1mm diameter piece of wire to avoid breaking here - I remember someone reported this after squeezing the lower wing. For a moment everything works fine.
The joints on the underside will require sanding, at the moment the CA glue is setting.
The exhaust outlet drilled out.
And the engine cowlings, which I plan to lay beside the model, are substantially thinned and with holes drilled at spots where brackets pass through. In earlier photos of the fuselage one may notice small holes drilled around the engine opening - I will add those brackets there.
« Last Edit: October 24, 2018, 01:11:03 AM by PrzemoL »
« Reply #27 on: June 18, 2018, 06:57:49 AM »
Nice detail work, Przemo.  Everything looks great!
« Reply #28 on: June 18, 2018, 03:24:00 PM »
Very nice work on the engine and the interiors, and very interesting tips on kit's assembly. I'm longing to see the next steps and the completed model.
« Reply #29 on: June 18, 2018, 08:47:04 PM »
Excellent progress here, this is looking like a really good build. Love those springs on the seatbelt attachments, pity they will never (hardly ever?) be seen again..... ;) I like the work on the cowlings as well, very nice.
What turnbuckles are you using? Are they Gaspatch and, if so, what scale?
