Under Construction
Clerget 9B (1/32, Taurus Models)
Topic: Clerget 9B (1/32, Taurus Models) (Read 8010 times)
PrzemoL
May 15, 2018, 08:11:44 AM »
While Łukasz from Taurus is waiting for box covers for his brand new Clergets I am privileged to receive one copy of Clerget 9B with a provisional box to try my hand on it - thank you my Friend!
The box is arranged in the way which those who saw his earlier Bentley will find familiar - the multitude of superb resin bits nicely put in the slots in soft foam holding blocks. What is new is the fine transparent resin stand and a clever jig for an easy tying of valve springs - needless to say a generous section of copper wire is provided too - two pieces of two different diameters to be honest - one for the said springs, another for electric wires.
So, let me take the Czech razor saw, let the fun begin and let us see if I will be able to do justice to amazing skills Łukasz enchanted in all those 280 or so elements.
I am still thinking if I should try to remove the kit engine from my Wilson's Camel and replace it with this jewel or to just attach it to the stand and have it as a completely separate model - which it surely is on its own.
Last Edit: May 25, 2018, 08:51:38 PM by PrzemoL
Re: Clerget 9B (1/32, Taurus Models)
May 15, 2018, 08:46:18 AM »
You are off to a great start as always. Having watched the progress and development of this masterpiece I am really looking forward to seeing your build!
Wodehouse
Jr. Member
May 15, 2018, 09:14:36 AM »
Łukasz is an absolute magician. What a beauty. This should complement my WNW Clerget Camel quite nicely, if I ever get around to building it..
Looking forward to what is certain to be a stunning build.
bobs_buckles
Freedom isn't free.
May 15, 2018, 04:35:00 PM »
Looking forward to seeing your work on this project, PrzemoL
Good luck!
vB
GazzaS
May 15, 2018, 04:42:26 PM »
Looking forward to seeing your results Przemo.
Gaz
There are only two states to be in: Queensland and blotto.
PrzemoL
May 16, 2018, 06:39:38 AM »
Work on the cylinders heads completed, Mounting tham to the crankcase began. Magnifying glass is mandatory.
The current part count stands on 90. And awe to Łukasz skills grows exponentially with the increasing number of attached parts.
Reply #6 on:
May 16, 2018, 08:26:09 AM »
You have made excellent use of the small jig included for ending the copper wire. The engine is coming together beautifully
Juan
All gave some, some gave all.
Reply #7 on:
May 16, 2018, 11:29:39 AM »
Beautiful work, my two cents, mount it separately, too beautiful to hide most of it under a cowling.
gbrivio
Reply #8 on:
May 16, 2018, 02:57:37 PM »
Quote from: Juan on May 16, 2018, 11:29:39 AM
I totally agree, it's a stand alone piece of modelling art.
PrzemoL
Reply #9 on:
May 16, 2018, 03:44:14 PM »
Thanks, guys.
My one cent :-) - if I attach it to Camel it will be with cowling and propeller off, fully exposed. The debate is still open.
aliluke
Reply #10 on:
May 16, 2018, 04:25:15 PM »
My two cents - it deserves to be on one of wonderful models. Your idea for a cowling off version of the Camel sounds great to me. And I'm sure you are going to do this engine kit all of the justice it deserves too!
Alistair
GazzaS
Reply #11 on:
May 17, 2018, 04:51:32 PM »
That engine may be too pretty to cover up... Might require a diorama of some sort...
Great work!
Gaz
kensar
Reply #12 on:
May 17, 2018, 09:37:25 PM »
"That engine may be too pretty to cover up.."
Yes, especially for the price you pay for it!
markleecarter
Full Member
Reply #13 on:
May 17, 2018, 10:36:31 PM »
You are doing an amazing job on an amazing model! Can I ask what glue you are using and how you are applying it? Also how are you handling the tiny pieces?
PrzemoL
Reply #14 on:
May 17, 2018, 10:46:43 PM »
Thank you, all.
The engine will surely not be covered. Nevermind money, but the quality of Łukasz product could not be treated like that.
I suppose I will try to take off the prop, engine and cowling from my Wilson's Camel. If it works, then this engine will replace it. If I see that would be too dangerous for Camel, then I will use the Taurus stand and have a model of Clerget itself.
For glueing I use CA glue, mostly in gel consistency. For some parts I prefer to dry fit them and if they are not easily removed to apply the glue and put them back - I do not remove them and then I use liquid CA glue to let it penetrate the slots. Both types I use are of "Kropelka" name - available in Poland but of Uruguay manufacture:
http://parkfarb.pl/uploads/_cache/2013/10/31/1286/800_600_1.jpg
For holding, I use either tweezers or my own fingers. The most tiny bits are transported by toothpick with wet tip - the adhesion action of water is enough to hold the bits.
Under Construction
