Author Topic: Internal Metal Tubing  (Read 2047 times)
Offline Ryan
« on: May 10, 2018, 12:52:45 AM »
Is there a set up or jig to make these joints look right using styrene rod.
The Roden 1/32 Schuckert's internal Z shaped structure is poorly rendered, so I figured I would scratch the effect.
Any tips on cutting rod at an angle or other techniques.
Ryan
Upcoming: Not sure!
Offline krow113
Re: Internal Metal Tubing
« Reply #1 on: May 10, 2018, 02:32:29 AM »
Draw the layout on paper.
Learn how to 'fishmouth' the tube or rod ends , any number of ways to do this.
Its not hard once you understand the procedure.
I would do the perimeter tubes first , then fit the inside pieces.
Side frames are usually first with crossmemebers fitted to suit.
Good luck!
