Author Topic: Fokker V.23 prototype scratchbuild  (Read 11025 times)
Offline Radarman
Re: Fokker V.23 prototype scratchbuild
« Reply #15 on: May 02, 2018, 05:43:48 AM »
Ken,
I just about jumped up and tried to do a back flip when I saw this one done.
That is one fine model and indeed, a fabulous tribute to Des. Thanks for sharing
this with all of us.
                            Kevin
« Reply #16 on: May 02, 2018, 06:10:32 AM »
Spectacular!
« Reply #17 on: May 05, 2018, 05:58:05 AM »
That is really a fantastic scratch build of a Fokker type, which I never have seen as model.
Very carefully build and painted.
Only a very mild criticism: I think the rubber of the tires was not black, more grey, but may be I'm wrong.
« Reply #18 on: May 06, 2018, 10:28:18 PM »
The tires probably were gray, but I used O rings for the tires and was hesitant to paint them.
Thanks for posting.
Offline RLWP
  • Bodger
« Reply #19 on: May 07, 2018, 12:06:53 AM »
Coward! Just because mine split...
« Reply #20 on: May 08, 2018, 09:40:10 PM »
The closer you are to completion, the more discretion is the better part of valor. ;)
Online NigelR
« Reply #21 on: May 08, 2018, 10:57:06 PM »
Very nice work, fantastic scratchbuild. And a fitting tribute to Des, very well done.
Offline RLWP
  • Bodger
« Reply #22 on: May 09, 2018, 07:18:21 AM »
Offline Berman
« Reply #23 on: May 09, 2018, 11:55:30 AM »
Passing along this tip from a model military vehicle website. Rubber tires must be first thoroughly washed with cleanser to remove all traces of mold release and skin oils. Then apply a 50/50 mix of white glue and water as a base coat. Allow to completely dry. Acrylic paint is recommended for final finish.
« Reply #24 on: June 03, 2018, 09:12:12 AM »
I am proud to announce that my Fokker won best of show at a local contest!
There were numerous well made models in contention - ships, armour, and figures, but I believe the fact that mine was scratchbuilt tipped the scales in my favor.
I would encourage others to try scratchbuilding.  Start small by adding small details to kit models and go from there.  Adding details you make yourself makes the model uniquely yours and not just an assembly of parts some one else made.
Offline krow113
« Reply #25 on: June 03, 2018, 10:13:43 AM »
Wicked!
The best validation.
Offline RLWP
  • Bodger
« Reply #26 on: June 03, 2018, 04:43:22 PM »
Very well done, Ken. I think I might have mentioned you are good at scratchbuilding....
A well deserved accolade
« Reply #27 on: June 03, 2018, 11:49:50 PM »
Congratulations Ken, well done and well deserved recognition! 8) 8) 8)
« Reply #28 on: June 04, 2018, 06:43:15 AM »
Big Ditto here !!!!
Online Mike Norris (UK)
« Reply #29 on: June 04, 2018, 10:46:36 PM »
That's one impressive scratch build - a tribute to your modeling skills and to Des - the best way to honor a great modeler.
